6.5's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 15th, 2012, 05:50 PM   #1
kmanxj5011
kmanxj5011's Avatar
Default 6.5's
My step dad just bought a d max. Thinking about buying his 96 3/4 ton 4x4 reg cab with 256000the miles for 3k. What you guys think? Anybody have or had a 6.5? Ideas? Pointers? Thoughts?
kmanxj5011 is offline   Reply With Quote
Old May 15th, 2012, 06:07 PM   #2
cj65
cj65's Avatar
Decent engines not a lot of power and don't like much more than stock boost
Old May 15th, 2012, 06:31 PM   #3
kmanxj5011
kmanxj5011's Avatar
Thats what ive heard. Its no cummins or d max bit tows good and will get me out of dding the heep. And its cheap.
Old May 15th, 2012, 06:58 PM   #4
Freak
Wheelin the HD
Freak's Avatar
isnt that a powerjoke? id pass but thats me. I dont know anyone thats had good luck with a ford.
Old May 15th, 2012, 07:08 PM   #5
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
6.5s are the old diesels in GM trucks. If i remember there were two different diesel's used in them, a 6.5L Turbo, and a 6.2L non turbo
Old May 15th, 2012, 07:10 PM   #6
kmanxj5011
kmanxj5011's Avatar
Yea gm's made by detroit diesel. Turbo 6.5
Old May 15th, 2012, 07:23 PM   #7
wave_crusher
I'll Direc your TV
...I suppose that didn't help any
Anyway, they were always a pretty reliable running engine. cj65 is right in that they didn't make a whole lot of power, but they DD pretty good. If your going with a diesel dd though, i'd try to find a 6.2L, they got better MPGs than the 6.5 turbos. i do know that the cylinder heads were prone to cracking on both v8s.
They get a lot of bad rap because they basically took an olds gas engine, threw some heads and an injector on it and called it a diesel. (olds also made a 350 diesel though)
Old May 15th, 2012, 07:49 PM   #8
Elusive
Elusive's Avatar
Elusive is offline   Reply With Quote
Old May 15th, 2012, 07:53 PM   #9
Lousypirate
Whoop Whoop
Lousypirate's Avatar
pretty sure you are talking about a different motor here.
Sent from my evo
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old May 15th, 2012, 08:03 PM   #10
kmanxj5011
kmanxj5011's Avatar
Sent from my evo
X2 thats how the olds 350 was. 6.5 was built by detroit diesel
Old May 15th, 2012, 08:11 PM   #11
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
You fucking retard, thats the motor in your truck
Old May 15th, 2012, 08:25 PM   #12
Renegade II
Coil springs are for pens
Renegade II's Avatar
...They get a lot of bad rap because they basically took an olds gas engine, threw some heads and an injector on it and called it a diesel. (olds also made a 350 diesel though)
False.
True.
True.
In 2000 they sold the design to AM General (G.E.P.= General Engine Products) and they made several changes to the casting design to stop the cracks and stiffen it up.
Old May 15th, 2012, 08:31 PM   #13
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
I DD my 6.5 in my 1993 with 292K and counting. Pulls good, 18 MPG, and away you go. The trans, 4L80E, was rebuilt just before I got it though.
Old May 15th, 2012, 08:53 PM   #14
wave_crusher
I'll Direc your TV
True, but where do you think Detroit diesel got the design for the 6.5 and 6.2
Old May 15th, 2012, 09:31 PM   #15
Renegade II
Wrong.
The gentelman at GM casting devolopment that assisted with the 6.2 & 6.5 design just happens to be my uncle. We've discussed the 6.5 in depth as he was curious about the improved G.E.P. engine in my H1. I can assure you that an Oldsmobile engine had nothing ever to do with a Detroit Deisel as the DD was a 'fresh' design because the Oldsmobile design was a miserable failure.
Old May 15th, 2012, 10:09 PM   #16
kmanxj5011
kmanxj5011's Avatar
Originally Posted by Renegade II View Post
Wrong.
Does he feel it's a decent engine?
Old May 15th, 2012, 10:40 PM   #17
Renegade II
Ya, it was never designed to be a powerhouse or hot rodded. Just a moderate HP deisel with decent fuel economy.
Put a fluid damper and a remote PMD heat sink on it if you get it. I also wouldn't throw over 10 PSI at a stock Detroit 6.5.
Page generated in 0.35393 seconds with 75 queries
