weldinto a diff - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 15th, 2012, 07:13 AM   #1
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Default weldinto a diff
I see that someone has done a 14 bolt bottom shave kit which required welding some plate to the bottom. I thought that mig welding to cast iron wasnt possible. is there something Im missing.
Old May 15th, 2012, 07:26 AM   #2
I suck cocks. Lots of them.
locally famous
is possible, has to be pre and post heated, most prefer nickel arc...i guess its easier to just say
Old May 15th, 2012, 07:56 AM   #3
Ive seen conflicting reports on if its cast iron or cast steel. cast steel is easier to MIG.
Old May 15th, 2012, 08:18 AM   #4
Jeeper52
Jeeper52's Avatar
more
Old May 15th, 2012, 09:13 AM   #5
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
rear end housing is cast steel not cast iron.
4x4xdodgeman is offline   Reply With Quote
Old May 15th, 2012, 09:23 AM   #6
bdd1469
bdd
bdd1469's Avatar
I've welded on lots of spring perches,gussets,and trusses with a mig welder,never had any problems.It may not be the best way,but it works.
I think (know)you have to heat cast iron before and after welding at a controled rate,I dont think this is necessary with cast steel axles.
Old May 15th, 2012, 11:32 AM   #7
Jeeper52
Jeeper52's Avatar
ttt
Old May 15th, 2012, 11:42 AM   #8
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Seems like Liv2mx used one that bolts on not weld???
RIP FULLSIZE4LIFE
Old May 15th, 2012, 11:45 AM   #9
deerebowtie
Unchained
deerebowtie's Avatar
reference from post 39 on. Its simple and easy to do if you have time.
http://www.pirate4x4.com/forum/showt...=116745&page=2
Old May 15th, 2012, 11:49 AM   #10
liv2mx
i like jungle gym's.
liv2mx's Avatar
the barnes 13 bolt kit is cheaper and easier. no welding needed.
ID:	92560   Click image for larger version
Old May 15th, 2012, 12:32 PM   #11
Originally Posted by Jeeper52 View Post
more
ttt
You really don't need to bump your thread twice in 4 hours when others are already responding.
Page generated in 0.35164 seconds with 57 queries
