2000 Pontiac Grand Am wont start after alternator replacement - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 14th, 2012, 10:41 PM   #1
awalters
Hired Badass
awalters's Avatar
Default 2000 Pontiac Grand Am wont start after alternator replacement
I know this is an offroad forum, but I know I'll get the best response here.
My friend has a 2000 grand am, V6, that had a starter go back. His brother pulled the starter without disconnecting the battery, and MAY have shorted the wires out. We put the starter back in, car ran great for a day of short trips, then it killed a battery.
We hooked it up to a MAC tools battery / alternator tester, and it sad bad diodes in the alternator. Today we put an alternator in it, jumped it and it ran for about 10 minutes, then died. Jumped it again, and tested it again and it came back "Good diodes, low reg." for the alternator test.
We put a different battery in it, started it, it ran great, still came back low reg. on the alternator. Put the old battery back in, put the good battery back in my truck, ready to call it a night, we tried to start his car and now it's getting NO POWER to the starter. When you turn the key the dash lights do like they would when you start it, but starter doesn't turn over.
The plan is to take the alternator back to the store tomorrow and ask for a different one (refurbished parts), but now that it won't even start that won't do us much good. Any suggestions?
awalters is offline   Reply With Quote
Old May 15th, 2012, 01:30 AM   #2
bdd1469
bdd
bdd1469's Avatar
Double check all connections,and fusible links would be my suggestion.I have repaired a lot of cars that had new batt,starter,and alt,when all they needed was a cable end or something similer.
Old May 15th, 2012, 05:14 AM   #3
Medina
Shoulda bought an Achieva
Medina's Avatar
Send a message via AIM to Medina Send a message via MSN to Medina
could be a junk alt, have it bench tested at autozone when you take it back and that will tell you for sure.
Medina is offline   Reply With Quote
Old May 15th, 2012, 05:34 AM   #4
Cool parts peddler
Ironman Offroad's Avatar
All that may have caused a Theft System problem.
Perform the pass key system relearn procedure after you take the POS alternator back for a good one.
You should charge the battery with a charger instead of asking the alternator to charge a dead battery because that is hard on alternators.
Ironman Offroad is online now   Reply With Quote
Old May 15th, 2012, 04:13 PM   #5
awalters
Hired Badass
awalters's Avatar
Thanks everyone for the help, it ended up being a junk starter from the parts store. The guy at the counter was well aware of them being junk. I guess that's the risk in refurbished parts. Either way it's good to roll, thanks guys.
Page generated in 0.18116 seconds with 38 queries
