how to set pinion bearing preload - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 11th, 2012, 10:15 PM   #1
hoyt5885
hoyt5885's Avatar
Default how to set pinion bearing preload
i have a dana 30 and put new pinion bearingd in it and was wondering how to set the preload on the pinion bearings and what the specs are and do i do it without the carrier in
hoyt5885 is offline   Reply With Quote
Old May 11th, 2012, 10:33 PM   #2
Tab
Tab's Avatar
Those use a crush sleeve. To do it right you would need a new crush sleeve and torque it down to the correct reading. You would need an inch pound, dial torque wrench to get it to the exact number once the sleeve begins its crush. Or you can do what most do and just put the pinion nut back on the the same spec as it was and hope for the best.
Old May 11th, 2012, 10:40 PM   #3
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
My yj hp30 uses shims for pinion bearing preload.
jpr Jeremy is offline   Reply With Quote
Old May 11th, 2012, 11:07 PM   #4
hoyt5885
hoyt5885's Avatar
it uses shims instead of crush sleeve
Old May 12th, 2012, 08:46 AM   #5
Tab
Tab's Avatar
I thought you were talking TJ 30. Then in that case you add or subtract the pinion shims to get the correct preload. Checked with the special torque wrench I mentioned earlier. And that should be done before you put a new pinion seal in too.
Old May 12th, 2012, 09:17 AM   #6
Cool parts peddler
Ironman Offroad's Avatar
I thought I showed you how to do that when you were here picking up the slinger washer?
Old May 12th, 2012, 09:33 AM   #7
Tab
Tab's Avatar
Oh and to do it "right" you'll have to have the carrier removed to get the pinion in and out to add/remove shims and to check the preload. Or just do whatever Dale told you to do because he's always right.
Old May 13th, 2012, 07:17 AM   #8
hoyt5885
hoyt5885's Avatar
dale u did my question is do i tighten the pinon nut till i get the right preload and then do the final torque on the nut
Old May 13th, 2012, 08:51 AM   #9
Tab
Tab's Avatar
It will only get get so tight if the correct shims are in there. The final torque on the nut is to just use a small dab of locktight and snug it down. I think the prefered method is to use a new nut every time its taken off too but I'm sure you'll be fine.
Old May 13th, 2012, 08:15 PM   #10
Impact wrench always solves everything.
Page generated in 0.53961 seconds with 53 queries
