Tire pressure on ".5" rims - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 10th, 2012, 09:19 AM   #1
87mopar
Web Wheeler :(
87mopar's Avatar
Default Tire pressure on ".5" rims
I have a 8800lb f250 with 39.5x16 on 16.5 rims. I'm a newb to this big of a tire and the 16.5 rim. I usually sit around 8-10lbs on the dunes. I've never had a truck this big. To my understanding a 16.5 tire doesn't "lock" on the bead of the rim. I planed on starting at 13lbs but am not certain if that's even ok. If it was any of my jeeps on any other rim I would be fine. My basic question is- I'm a newb what tire pressure is good for a 39.5x16. R16.5 on a f250?
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old May 10th, 2012, 09:24 AM   #2
Monster80
Monster80's Avatar
It depends on the load range. Heavier load ranges you can run lower pressure and lighter higher. And also the rim width.
Monster80 is offline   Reply With Quote
Old May 10th, 2012, 09:25 AM   #3
87mopar
Web Wheeler :(
87mopar's Avatar
Durr should have added that load range D
Old May 10th, 2012, 09:30 AM   #4
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Where did you come up with 8800lbs? Does it have a engine in the back and front?
Old May 10th, 2012, 09:31 AM   #5
Monster80
Monster80's Avatar
It would be safe to run around 10lbs. That's what my brother runs on his chevy 2500 same tire and rims and They haven't came of yet. But much lower than that your tempting a flat.
Old May 10th, 2012, 09:33 AM   #6
Monster80
Monster80's Avatar
My cousins 4 door f250 weights 8800lbs
Old May 10th, 2012, 09:36 AM   #7
87mopar
Web Wheeler :(
87mopar's Avatar
That is what mine is
Old May 10th, 2012, 09:37 AM   #8
87mopar
Web Wheeler :(
87mopar's Avatar
That is what mine weighs but my question is does that rim size matter?
Old May 10th, 2012, 09:39 AM   #9
Monster80
Monster80's Avatar
No it doesnt matter
Old May 10th, 2012, 09:40 AM   #10
Monster80
Monster80's Avatar
It might be a little work getting them on but it will work
Old May 10th, 2012, 09:43 AM   #11
87mopar
Web Wheeler :(
87mopar's Avatar
Alright thanks
Old May 10th, 2012, 09:45 AM   #12
BigBlockBlazer
Axle breakin' 101
That's f*cking heavy, and 8-10 should be fine.
Old May 10th, 2012, 09:50 AM   #13
bigbchevy
missmrgreenagain
bigbchevy's Avatar
16.5s suck
H.o.r.e
Old May 10th, 2012, 10:01 AM   #14
BigBlockBlazer
Axle breakin' 101
Originally Posted by bigbchevy View Post
16.5s suck
Yes
Old May 10th, 2012, 08:48 PM   #15
8800 lbs is likely your gross vehicle weight rating, not your weight. They tend to weigh around 5800-7000, depending on cab configuration and engine.
Old May 10th, 2012, 08:55 PM   #16
Renegade II
Coil springs are for pens
Renegade II's Avatar
Buy a set of innerairlocks from Ironman. Otherwise no lower than 10 PSI on a 9.75 wide rim.
Old May 10th, 2012, 11:02 PM   #17
Elvis13
??? That seems pretty low.
If his truck is a 4wd, 4 door diesel with 39.5 tires i would think it weighs over 8k.
Old May 11th, 2012, 05:03 AM   #18
87mopar
Web Wheeler :(
87mopar's Avatar
My rims are 12" wide, and no diesel
Old May 11th, 2012, 05:25 AM   #19
Monster80
Monster80's Avatar
That could cause a problem being such a wide rim.
Old May 11th, 2012, 05:35 AM   #20
GMKLR50
Broke wheeler
GMKLR50's Avatar
get these $800ish from ironman installed, save the trouble, I still havent but dont drop my 16.5 x 12 rims under 12 psi in the warm days 15 in the snow. mine are D range tires and Bias
carry a spare, or air, or both, as everyone siad 16.5's suck. You could try welding on a bead to make the rims work like all the rest it will cost you less the inner airs but makes it a pain to put on the tire I am told.
GMKLR50 is offline   Reply With Quote
Page generated in 0.43314 seconds with 83 queries
