271 ford t case,will a dodge 271 23 spline input fit? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 9th, 2012, 01:53 PM   #1
liv2mx
i like jungle gym's.
liv2mx's Avatar
Default 271 ford t case,will a dodge 271 23 spline input fit?
after more research i found the ford 271 t case out of the superduty is one of the strongest cases made.(they are actually rated better then a 205) they come stock with a 24 29 and 31 input shaft.dodge started putting the 271 in the 03 and newer 1 tons.they have a 23 spline input but a slip yoke.ford has a fixed yoke on both the front and back.(you can put the ford fixed yoke output onto the dodge case but i would have to buy 2 cases then) have called a few places and i am 80% sure i can get the 23 spline input from the dodge 271 and put in the ford 271.anybody have any facts on this?
called advanced adapters and they said they have swithched all but the 23 spline input so they could not tell me 100% if it would work but they thought it will. i can get a ford 271 for 300 bucks and the input from the dodge for 50 bucks. anybody have any ideas on this?
Old May 9th, 2012, 05:17 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
From some Google searches looks like it, maybe even use a 231 input?
On a side note might be interested in the ford input if it would work in a 231....
Old May 9th, 2012, 05:56 PM   #3
liv2mx
liv2mx's Avatar
i have a bunch of the 231 inputs on the floor, that would be nice..i do have a couple of the chevy big chain 231 and i even have the terra low case.so maybe i will just buy it and tear it apart and see what will work.
this is one of the charts i could find.i have googled everything and no real facts oin what will work.i know the ford fixed yoke bolts up to the dodge and i know advanced adapters told me the 271 is stronger then an atlas.
Transfer Case Specifications Chart
Transfer Case Model No. Max. Capacity Torque (Current Application) Weight lb. Weight kg. Oil Fill Capacity pints Oil Fill Capacity Liters Approx. Vehicle Weights
lb.-ft. N-m GVW lb. GVW kg.
Active On Demand NV 126 1590 2156 67 30 4 1.9 5300 2404
Active On Demand NV 136 1590 2156 70 32 4.2 2.0 6000 2721
Active On Demand NV 226* 2299 3117 78 35 4 1.9 5300 2404
Active On Demand NV 236 2299 3117 84 38 5.1 2.0 8600 3900
Active On Demand NV 246* 2281 3093 86 39 5.1 1.9 8600 3900
Part Time NV 231* 1885 2556 65 29 2.5 1.1 5920 2691
Part Time NV 231HD 1940 2631 72 33 2.5 1.1 6400 2909
Part Time (Electric Shift) NV 233 1591 2157 74 34 2.5 1.1 5300 2409
Part Time NV 241* 5555 7533 80 36 5 2.3 8800 4000
Part Time NV 241HD* 5555 7533 100 45 6.5 3.1 11000 5000
Part Time (Electric Shift) NV 243 1785 2420 84 38 4.9 2.3 10000 4545
Part Time NV 261* 2564 3477 69 31 5.1 2.4 7200 3300
Part Time NV 261HD* 5430 7362 77 35 5.1 2.4 10000 4500
Part Time NV 261SHD* 5677 7697 78 35 5.1 2.4 12000 5500
Part Time (Electric Shift) NV 263HD* 5430 7362 81 37 4 1.9 10000 4536
Part Time (Electric Shift) NV 263SHD* 5677 7697 84 38 4 1.9 12000 5443
Part Time NV 271** 7890 10700 120 54 4 1.9 17500 8000
Part Time (Electric Shift) NV 273** 7890 10700 123 56 4 1.9 17500 8000
Full Time Plus Part Time NV 242 1486 2015 86 39 2.85 1.3 5500 2500
Full Time Plus Part Time NV 242HD 2028 2750 90 41 6.5 3.1 6400 2909
Full Time Plus Part Time NV 242HD AMG 2340 3173 90 40 5 2.35 11500 5227
Progressive On Demand NV 247 1800 2442 83 37 2.5 1.1 6000 3000
Full Time NV 124 3482 4721 42 19 1.54 0.7 5336 2420
Full Time NV 125 3482 4721 51 23 1.54 0.7 5512 2500
Full Time NV 149AWD 2203 2987 80 36 4 1.9 6800 3084
Full Time NV 249 1800 2442 98 44 2.5 1.1 6000 2700
On Demand NV 249OD 2030 2754 84 38 2.5 1.1 6000 2700
Old May 9th, 2012, 06:53 PM   #4
liv2mx
liv2mx's Avatar
after doing some more research this is a badass case! they rate it at almost 18000 for torque. the sled pulling guys say they blow the shit out of there 241 and put this case in and have no more worries.34 spline outputs and you can run a 1480 joint. it is a big ass case though. i believe i just scored a demo to try, so i will tear it down and see what i can figure out.
Old May 9th, 2012, 08:32 PM   #5
busyfixin
Balls Deep
busyfixin's Avatar
Yes, the 271 is a badass case. It's biggest downfall is not being twinstickable. I have a Dodge input (29 spline) that I plan to put into a Ford case for the Cummins wheeler I am building. I know that will swap just fine. I don't know for sure about the 23 spline as I have only read online that it will and have never tested it. It's too bad all this blabbering is completely useless to you.
Old May 10th, 2012, 07:23 AM   #6
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
They are huge. Make sure it will fit your chassis.
Old May 10th, 2012, 09:04 AM   #7
liv2mx
liv2mx's Avatar
i talked to a place yesterday that builds these and they said the 23 spline dodge input will swap into the ford case. yes that is my only concern is it is a big case.i have to do some measuring, these can be found real cheap so it might be worth changing a couple tubes.
i dont care about a twin stick so i hope it will work.found some other cases yesterday also for cheap so i have my t case decisions done.
Old May 13th, 2012, 10:55 PM   #8
busyfixin
Balls Deep
busyfixin's Avatar
Any links to cheap cases you don't need? I need a Ford case right now.
Old May 14th, 2012, 12:15 PM   #9
liv2mx
liv2mx's Avatar
what kind of case u need? i know where this is a few different ones and i have a couple.
Old May 14th, 2012, 09:30 PM   #10
busyfixin
Balls Deep
busyfixin's Avatar
Ford 271 with fixed yoke. If the price was cheap, I could use a Dodge 271 for a different truck also.
Page generated in 0.35444 seconds with 53 queries
