Starter relay question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 8th, 2012, 01:06 PM   #1
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Default Starter relay question
I hear that you can like... put in a hidden switch to turn off and on the power coming from the starter relay or something like that. Just for added security. Anybody know anything about this? Done it? Let me know!
Old May 8th, 2012, 01:42 PM   #2
jerm97xj
I fixed it!!!
jerm97xj's Avatar
I dont know what kind of vehicle you want to install this on.
This is one of many ways you could do this.
jerm97xj is offline   Reply With Quote
Old May 8th, 2012, 02:39 PM   #3
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
It's for a 02 TJ
Old May 9th, 2012, 07:15 AM   #4
cerial
Direct Drive FTW
cerial's Avatar
All your talking about doing is installing a throw between the battery and relay. Basically if your relay is exposed in any way it can be "jumped" to start the car. I have done it numerous times driving pos over the years.
Your best (factory look) bet is to bury the relay under the dash and run the 12v lead to it then to the starter. With it inside it is more difficult to jump then someone simply tossing the hood up on your tj and starting it with a small piece of wire.
If your relay is on the starter then you can install a torx bolt on cover that will simply not let a wrench through.
Just install a master power switch under the dash somewhere and you will be good. That's enough of a PITA to look for that the thief will just leave you with a torn top.
Old May 9th, 2012, 10:53 AM   #5
Elvis13
People must be desperate if they're stealing 10 year old Jeeps.
Old May 9th, 2012, 11:09 AM   #6
Yota Bill
Waste of time. 90% of the thieves that would try to steal it will not be fooled or even slowed down by that. There are countless options that are much better. Just put in a removable steering wheel, that would be slightly more effective.
Page generated in 0.17979 seconds with 42 queries
