truck shaking - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 8th, 2012, 01:19 PM   #1
storey618
storey618's Avatar
Unhappy truck shaking
when my truck gets around 45-60 it has a very annoying shake. the previous owner said it was the torque convertor but i dont wanna immidiatly drop the trans. what else could it be?!?
storey618 is offline   Reply With Quote
Old May 8th, 2012, 01:58 PM   #2
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
Tires, driveshaft, the dreaded deathwobble, maybe something else...
Without more info it's impossible for anyone to help you.
Old May 8th, 2012, 03:57 PM   #3
jbsjunk
Little Member
jbsjunk's Avatar
+1 on info. What is it? Chevy? Daihatsu?
Old May 8th, 2012, 04:10 PM   #4
Rx7Kevin
Does it occur more on coast or accel? is it with it in gear or is it speed related only? Where do you feel it specifically?
Rx7Kevin is offline   Reply With Quote
Old May 8th, 2012, 04:11 PM   #5
storey618
storey618's Avatar
1998 gmc Sonoma zr2. 31'' tires,
Old May 8th, 2012, 04:14 PM   #6
storey618
storey618's Avatar
If I let off the gas mid shake it'll stop. It happens usually around 50 mph and the whole truck shakes
Old May 8th, 2012, 04:40 PM   #7
storey618
storey618's Avatar
Everything I've read online says tires so that's what I'm doing first
Old May 8th, 2012, 05:07 PM   #8
montecarlo33
The Violator
montecarlo33's Avatar
I would jack up the truck and check tightness in the front end first, those trucks are famous for balljoints, tierods, wheelbearings. If all thats tight I would look into the tires and if they are balanced, maybe you lost a wheel weight or somthing along the way. all i know is I would really make sure I checked the front end before I took the trans out.
Old May 8th, 2012, 05:42 PM   #9
storey618
storey618's Avatar
Alright well now the water pump is leaking do that's new number one priority thanks
Old May 8th, 2012, 06:07 PM   #10
Hunter9
Not Right!
Hunter9's Avatar
Does this truck have a carrier bearing on the drive shaft?
Hunter9 is offline   Reply With Quote
Old May 8th, 2012, 06:10 PM   #11
MilwaukeeF350
Dan
Sound like u-joints on driveshaft going bad.
Can you pop in neutral at those speed to check if it go away or it still there.
Check Front end to make sure it tight no sloppy or loose.
If Previous Owner say it torque convertor so can you check flex and torque convertor to see if it been loosen. But I don't believe this one it would shaking all times plus rattle noise.
Old May 8th, 2012, 06:17 PM   #12
storey618
storey618's Avatar
What's a carrier bearing?
Old May 8th, 2012, 06:21 PM   #13
MilwaukeeF350
Dan
Old May 8th, 2012, 06:27 PM   #14
storey618
storey618's Avatar
I don't think so
Old May 8th, 2012, 09:10 PM   #15
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
u joint or mid shift bearing. iirc it has one unless someone switched the shaft over
Old May 8th, 2012, 09:13 PM   #16
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Take it to someone who knows what they are doing.
Old May 8th, 2012, 09:31 PM   #17
storey618
storey618's Avatar
Fuck that lol
Old May 8th, 2012, 09:34 PM   #18
Ridin Dirty
Fuck that lol
I see. Well, good luck chasing your tail trying to figure this out then. Just start flinging parts at it until it is fixed or you are out of money.
Old May 8th, 2012, 09:37 PM   #19
storey618
storey618's Avatar
What the hell man? You don't have to be a dick cuz i wanna solve my own problems rather than throw them at someone else
Old May 8th, 2012, 09:41 PM   #20
Ridin Dirty
First I read all of your posts in this thread. Then I gave you advice that you should listen to based on what I read in those posts. Then I said good luck. Should I start being a dick?
Page generated in 0.35804 seconds with 83 queries
