F'n Rod Bearings?? Drill out ports?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2012, 10:15 PM   #1
travis
travis's Avatar
Default F'n Rod Bearings?? Drill out ports??
Ok I've had 1 22r and 2 22re's apart now to find bad rod bearings on all of them! WTF? There has to be a root problem here... I noticed there is an oiling port at the base of the rods. When I stuck a drill bit into the hole frome the bearing side I discovered that it necks down right at the end of the port. Can anybody give me a good reason not to drill that out all the way through to maybe help keep those lubed?
travis is offline   Reply With Quote
Old May 9th, 2012, 12:24 PM   #2
BOGDOG
BOGDOG's Avatar
How many miles were on the engines? Could be the bearings are just worn out or possibly wiped out from antifreeze in the oil. I'm not sure but weren't the RE's discontinued in the mid 90's and the last 22R motor was probably built in the late 80's. These engines are known for there durability. I would think the engineers designed the lube system to supply the right amount of oil to the bearing. If you drill them out you could starve something else
Old May 9th, 2012, 12:37 PM   #3
Yota Bill
Its done that way to cause a restriction to oil flow which is where the oil pressure comes from. I would suggest not drilling them out unless you want high oil flow with virtually no oil pressure.
Old May 9th, 2012, 02:19 PM   #4
kickstand
circling the drain
kickstand's Avatar
weird, my 22re had wasted rod bearings too....and only 125k miles. These engines are extremely durable little peices of shit
Old May 9th, 2012, 03:06 PM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I
H.o.r.e
Old May 10th, 2012, 12:28 PM   #6
BOGDOG
BOGDOG's Avatar
Like I said before you sound like a detroit politician keep repeating a lie until the dumbasses belive it to be true.
Old May 10th, 2012, 01:35 PM   #7
kickstand
circling the drain
kickstand's Avatar
how the fukc am I lying?
my motor had 2 spun rod bearings and 2 rod bearings that were so thin that one of them broke as I pulled it off the crank it was half welded to.
Fact, 2 spun rod bearings.
Fact, a camshaft that was warn down to holy hell.
Fact, a dealer maintained truck with maintenance records to prove it.
Fact, 125k miles
Fact, it was the most durable and long lasting motor I have ever owned (there, I lied just to make your dumbass feel better)
I mean fukc , do you even know what a lie is?
I mean, he has taken how many 22r(e)'s apart and they had bad rod bearings, and mine did also, we're both lying aren't we? We're just making it up?
Are you retarded?
Old May 13th, 2012, 10:21 AM   #8
BOGDOG
BOGDOG's Avatar
Everytime somebody asked a question about that motor your punkass says they are all junk, that is a lie. Like I asked him how many miles were on his motors. What do you think would happen to the rod bearings after you run the cam particles thru them?
Who adjusted the valve lash to caude the camm to wear down?
This is supposed to be a tech forum not a place for dickstand to rant about his experiace with one motor. If you have nothing useful to add why do you even bother to post asshole? I've had several without issue. Back in the late 80's early 90's I used to buy rangers S10's with bad motors and swap in motors to resell them. Ford 2.0 motors in rangers lasted about 50k before the needed rings. 2.5l S10's went about 80 or 90k before the heads were cracked and needed replacement. I never found a Toyota that needed a new 22RE. While 125 on yours may not be a lot for a Toyota sure beats most of the 80's 4 cyl trucks I've seen. So you keeping flapping your gums and if people are dumb enough to listen thats their problem asswipe.
Old May 13th, 2012, 10:25 AM   #9
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old May 13th, 2012, 10:35 AM   #10
Toivo
Feel lucky?
Toivo's Avatar
I have a 22re with 190k and has never been pulled down. 1990 yota pickup.
Old May 14th, 2012, 08:16 AM   #11
kickstand
circling the drain
kickstand's Avatar
It sounds like you have a sore pussy? You're boyfriend forget to use some l;ube last time?
Funny, he's got two motors with bad rod bearings, I also had one. But, since you're so fucking awesome, maybe our motors don't exist and we shouldn't have had those experiences?
I had an S-10 with well over 100k miles, you must be lying about your s-10's because clearly since mine was trouble free they all must have been.
I hate when my ford only lasts 50k miles.
You're an ignorant fukc . I mean honestly you are. I know you prefer asians because they have smaller penis's making it easier for you to gobble up their shower soldiers and fullfill your fagot ass tendencies, and maybe that's why your pissed that since someone was discussing his frustration with his toyota and the worn out rod bearings I also commented (you know since I had the EXACT same problem with my little motor), but regardless of that you're doing the same hypocritical thing you are complaining I am doing because you had oodles and oodles of shitty fords and s10's you used to buy to make money off because you are so fucking awesome. I mean, you really are awesome (in a fucktard kind of way)
I mean, the 22re is awesome, for most people, but it wasn't for me, or the OP, or a handful of other people that I encountered while rebuilding mine....but then again, no body is as awesome as you, I don't even know you and I know this is true.
Old May 14th, 2012, 04:15 PM   #12
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I am a toyota guy....the 22re is not what its hyped up to be....i cant wait till I can swap mine out.
Old May 15th, 2012, 08:05 AM   #13
kickstand
circling the drain
kickstand's Avatar
agreed. Mine was a gutless wonder with terrible durability compared to the awesomeness everyone else experienced.
I'm sure if you never went over 3,000 rpm and changed the oil ever week it would be fine.
My room mate in college had a 4 runner with the 3.0 (an engine i recall being told to avoid) with well over 200,000 miles on it. It had no more power then my 22re, but it ran forever.
Old May 15th, 2012, 08:24 AM   #14
I suck cocks. Lots of them.
locally famous
never heard of an s-10 dying...from anything. except rust. just sayin
Old May 15th, 2012, 08:37 AM   #15
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
2.5 iron duke? I've had a few with 170k untouched. Pretty stout motors. I'm a ford guy but I have to admit those 80's 2.3 weren't known for lasting, between my dad and my uncle they've had a dozen and @ 140-150k they'd be piston slapping mofos.
Old May 15th, 2012, 08:58 AM   #16
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
The 3.0 was one of those motors where you either got a good one that lasted forever or you got one that died almost instantly. The ones I have had have been great....they are gutless but reliable as can be.
The best motors I have ever owned have been the two 3.4's in my tacomas...both had 200k, both had good power, didnt use oil, ect ,ect and I was not easy on either....i will be replacing my 22re with one.
Old June 10th, 2012, 12:41 PM   #17
Yotabalt
Locked In
Yotabalt's Avatar
My toyota has a 3.0, it has 255,000 miles on it, I know the last 2 owners beat the living hell out of it...like with no mercy (they thought Toyota's can hold 6500 Rpms forever) and it still runs and could wheel with it, but as everyone else has been complaining about, the rod bearings are toast...but if it took 255,000 to kill this old bitch, I would have to say they are a good truck, not too hard to work on and are actually fun to drive...
I had a 97 ranger that i whooped to death, at 118,000 I pulled the running motor amd trans out, and swapped in a stang 3.8L(yeah it was no better than the 2.3)
Then I swapped in a Chevy 350, and and whooped that till, you guessed it, the rod bearings went on that too lol....I think it's just the luck of the draw...(live by the birthdate on the tag, Friday and Monday are terrible build days haha)
Yotabalt is offline   Reply With Quote
Page generated in 0.43904 seconds with 74 queries
