Gm 14 bolt wheel studs??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2012, 10:19 PM   #1
chriszildjian17
chriszildjian17's Avatar
Default Gm 14 bolt wheel studs???
I am doing a sas swap on my 95 k1500. I have a hp dana 44 front. It has 1/2 x20 wheel studs.. I also have a 10.5 14 bolt im building for the rear. Can i get matching studs for the rear so i dont have to have 2 different size lug nuts. I think it has 9/16 studs now. If so where can i get them. need longer ones for the rear disc conversion.
chriszildjian17 is offline   Reply With Quote
Old May 6th, 2012, 10:43 PM   #2
MiNi Beast
MiNi Beast's Avatar
best way I found when dealing with studs is get out your mics and go through the book. GL.
http://www.dormanproducts.com/catalo...ec10_Part3.pdf
Old May 7th, 2012, 07:59 AM   #3
chriszildjian17
That helps, thank you.
Old May 7th, 2012, 02:00 PM   #4
MiNi Beast
MiNi Beast's Avatar
Well I'm not going to [post something that won't help, I'm not steveo,
Old May 9th, 2012, 04:06 PM   #5
chriszildjian17
ok so i am just going to have to suck it up and buy 2 different size lug nus. LOts of resaerch and found many studs with .622 kurl but none with that length(3.25) in 1/2 x 20.need longer ones for the disc brake swap, and i'm running aluminum wheels.
Old May 9th, 2012, 04:24 PM   #6
TanTahoe
TanTahoe's Avatar
What is the 14 bolt out of?
I believe my 9.5 14 bolt SF has M14 studs. My Ford Dana 44 now has the matching 6 lug studs. I was about to get a 15.25MM drill and a (I believe) 37/64 drill (Id have to check to be sure).
You might want to look into something like that. Find a stud that works for your app and drill the holes out bigger.
TanTahoe is offline   Reply With Quote
Old May 10th, 2012, 10:11 AM   #7
chriszildjian17
i will look into it thanks.
Page generated in 0.23845 seconds with 44 queries
