Ford 60 changed to chevy drop - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2012, 05:30 PM   #1
big86inthestixx
big86inthestixx's Avatar
Default Ford 60 changed to chevy drop
Tell me if im smoking dope...
I want to take a new ball joint Dana 60 out of a superduty and pull the tubes and change it to a chevy drop. Sounds pretty simple...but is it worth the $ savings vs buying a chevy Dana 60.
Sent from my SPH-D710 using Tapatalk 2
Old May 6th, 2012, 05:43 PM   #2
joe_jeep
welfare wheeler
joe_jeep's Avatar
you would gain a hi pinion axle. it is slightly stronger in a front application.
if you got the sd axle cheap enough, it would be a great option.
say you find a chevy axle for $800, and you can find a sd axle for $400.
in reality its probably cheaper to buy a chevy axle, even if you do it yourself.
gonna cost a chunk of change to re-tube and make mounts, assuming you do it yourself.
unless it will take a ton a fab work to put it in, then you might as well fab the sd axle.
if you have to farm out the re-tube and mounts than by all means buy a chevy axle.
its possible you are smoking dope either way? i would not know? enjoy!
Old May 6th, 2012, 05:45 PM   #3
Tab
Tab's Avatar
Depends how bad you want a high pinion axle. And if you can do the work yourself or have a good hook up on getting it done to save some money. If you have to re tube it anyway then you may as well.
Old May 6th, 2012, 05:58 PM   #4
big86inthestixx
Well I would way rather have a high pinion..of course. Superduty axles are a lot easier to find..for me anyway. And they have unit bearings, dual piston calipers, and balljoints. For MY rig the ball joints should hold up fine assuming they are bigger than Dana 44 stuff, going to need to do high steer.
How much $ are we talking for a chunk of axle tube? Only really need it for the long side correct.
Thanks guys.
Old May 6th, 2012, 09:05 PM   #5
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
are you bolting the axel in stock sup? pass side has no preach for your spring to set on the center section on the ford axel. you do not have retube both side only one side. one side you just cut down the tube length, cut c part off.
4x4xdodgeman is offline   Reply With Quote
Old May 8th, 2012, 12:18 PM   #6
chasetheface123
chasetheface123's Avatar
Ive got a SD axle here. Pm me if you are intrested..
chasetheface123 is offline   Reply With Quote
Old August 14th, 2012, 09:33 PM   #7
big86inthestixx
Well there it is, chevy superduty 60. So far it has cost me 600$, and basically twisted my arm to do 4 link front.
So it is possible not too big a pain in the butt. And its pretty sweet when its all done.
Old August 14th, 2012, 09:44 PM   #8
Did you narrow the wms to? Whats the plan for the pass side? Doesn't look like theres any room to attach to the tube unless your attaching right off the diff housing itself.
Old August 14th, 2012, 09:52 PM   #9
big86inthestixx
Kept the axle length stock to keep shafts easily available, and there is about 1.5" of available tube on ths pass side. tonight I removed a little casting on that side to make it about 3" of open tube. You may or may not be able to see in this picture.
Old August 14th, 2012, 09:53 PM   #10
big86inthestixx
Oh btw the front axle measures 3" wider than the rear, Im ok with that, others may not be.
Old August 14th, 2012, 09:54 PM   #11
Yeah really can't lol. I removed about 1.5" out of my diff housing on my 95 BJ 60 to give a little more tube to attach to as well.
Old August 25th, 2012, 09:21 PM   #12
big86inthestixx
Here's a pic of the superduty 60 swapped, all linked up. Close to ready for paint.
Old August 30th, 2012, 12:02 PM   #13
chasetheface123
No linky in the post.
Old August 31st, 2012, 02:47 AM   #14
big86inthestixx
Oops..
Old September 1st, 2012, 09:42 PM   #15
big86inthestixx
Well here is a close up of the axle installed..
All swapped.. linked, and painted.
Page generated in 0.35327 seconds with 69 queries
