D30 clicking..? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2012, 09:51 PM   #1
Daniel
SFA Ranger
Daniel's Avatar
Default D30 clicking..?
I've checked everything. The axle joint isn't very old and the bearing rolls smooth.
It's been making this noise, but over the past few weeks it keeps getting louder.
The noise is only when I'm going forward. I've been reading about the brake pads chattering, but I'm not sure if that could be the issue.
Hopefully it isn't anything serious.
http://s88.photobucket.com/albums/k1...t=9b7a34f1.mp4
Daniel is offline   Reply With Quote
Old May 6th, 2012, 08:40 PM   #2
Daniel
SFA Ranger
Daniel's Avatar
Popcorn anyone?
Old May 6th, 2012, 08:58 PM   #3
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
i would remove and inspect the wheel bearings as that sure sounds like the culprit to me from the video
HPandThrottle is offline   Reply With Quote
Old May 6th, 2012, 08:59 PM   #4
Daniel
SFA Ranger
Daniel's Avatar
I have a 94 Wrangler axle under the front. It has unit bearings.
Old May 7th, 2012, 04:34 PM   #5
HPandThrottle
It sure sounds like a flat spot in a bearing so I would look closer at all bearings and joints then
Old May 7th, 2012, 06:29 PM   #6
Daniel
SFA Ranger
Daniel's Avatar
The noise goes away when I hit the brakes and I can move the caliper around if I grab the brake hose.. I don't think that is normal.
All of the bolts are tight and the bearings roll smooth.
Old May 7th, 2012, 09:04 PM   #7
HPandThrottle
if you can move the caliper around like that something is far from right there but bearing noises usually go away when the power is not being applied i would start with the caliper knowing that
Old May 7th, 2012, 09:23 PM   #8
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
Unit bearings can go bad also.
Old May 7th, 2012, 09:25 PM   #9
Daniel
SFA Ranger
Daniel's Avatar
Wouldn't it be a constant noise if it was bad? It doesn't make the noise in reverse or when I hit the brakes.
Sent from my iPhone 4S using Tapatalk
Old May 7th, 2012, 09:45 PM   #10
brewmenn
brewmenn's Avatar
Yes, a bearing noise will usually go away when you hit the brakes. The noise is from the outer part of the bearing moving around. When you hit the brakes the pads clamping down on the rotor prevents the movement, thus stopping the noise.
I'm not sure about the reverse part.
Old May 7th, 2012, 09:52 PM   #11
Wramblerguy
Wramblerguy's Avatar
x2
your calipers shouldnt move, fix that and report back
Old May 7th, 2012, 11:29 PM   #12
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Does it make a difference if you are in 4wd or not? Check and/or take out your front drive shaft. See if the problem is fixed.
Old May 8th, 2012, 01:59 AM   #13
Daniel
SFA Ranger
Daniel's Avatar
No. I've checked that already. All of the u-joints are new, same with the balljoints. Idk how old the wheel bearings are.
After wiggling the caliper around and making sure the bolts for it were tight, I'm assuming the "slides" are bad/worn out.
They are getting replaced tomorrow.
Page generated in 0.42176 seconds with 62 queries
