Bell housing dial indicator recommendations - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 4th, 2012, 11:43 PM   #1
cerial
Direct Drive FTW
cerial's Avatar
Default Bell housing dial indicator recommendations
I am coming back to Michigan at the end of the month and wanted to mate the engine to the transmission. I have like 3 sets of adjustable dowel pins so I am set there, once I pound the stock old ones out.
I am looking for recommendations on a good dial indicator to use for aligning a 465 bell housing. I really only expect to use it for aligning the bell housing then expect it to get borrowed or lost before I return at Thanksgiving. I am curious about the ones under $200 from Jegs and such. But, accuracy> cost in this one time use application.
Thanks in advance for any advise.
Old May 4th, 2012, 11:57 PM   #2
boggin-machine
boggin-machine's Avatar
What's wrong with the stock pins??
Old May 5th, 2012, 12:07 AM   #3
Yota Bill
borrow one, or offer to rent one from someone
Old May 5th, 2012, 09:08 AM   #4
bdd1469
bdd
bdd1469's Avatar
I've built at least twenty axles with a $20 special from a traveling tool sale,I have never had a problem.I believe you are just trying to center your bellhousing? Even the cheapest dial indicator should work,as it will be consistently accurate,or consistently not accurate.
Old May 6th, 2012, 08:23 PM   #5
cerial
Direct Drive FTW
cerial's Avatar
Taken with a camera phone last Thanksgiving. This is as close as I could get the 420 bell (sold to me as a 465 bell) to the motor due to the current pins. PO had a automatic on it I believe.
Bought a dial indicator/base kit one from Jegs, it is in the mail. Thanks for the help.
Old May 6th, 2012, 08:32 PM   #6
deerebowtie
Unchained
deerebowtie's Avatar
what engine is this? a 420 bell shouldn't even fit over the bearing retainer on a 465? sure you don't have a np435 bell or a pre '58 chevy? The dowel pins on my last 454 I had to hit with some emery cloth to get to fit - they were physically larger than the holes on the mid 60's passenger car bell I'm using.
Old May 7th, 2012, 12:09 AM   #7
cerial
Direct Drive FTW
cerial's Avatar
The engine is a 70's 350. That cast bell was a 420, I was lied to it happens when you buy junk off the net. Cast 420 bells are very easy to find, cast 465 bells are getting harder. I will find something to use the 420 bell on later.
I have since bought 2 aluminum 465 bells both that were mated to 350's with all the used hardware and made sure they were the correct diameter for the 465.
Page generated in 0.22526 seconds with 44 queries
