2012 f-150 help!? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 4th, 2012, 04:34 PM   #1
OldManGrand
Default 2012 f-150 help!?
so i ordered the blistein 5100's for my truck and will be running them at the highest setting, but i don't want the front to be nose high so i would like run either a 3in block or add-a-leaf to maintain a slight rake. which one would provide that with out being to ass-high and not need shocks immeidiatly?
OldManGrand is offline   Reply With Quote
Old May 4th, 2012, 04:42 PM   #2
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
Usually two or three inches up in the front will level it off, with no need to fix a nose high condition.
What did you do to the front to lift it? Shocks alone won't lift it.
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old May 4th, 2012, 04:59 PM   #3
OldManGrand
sorry should of clarified they are the blistein 5100's that have the hieght adjustment for the perch, so it pre-loads the spring and raises the front end, the highest setting is 2.25 but actually yeilds 2.5in of lift .
here's the link, they have great reviews and people seem very happy with them.
http://www.bilsteinus.com/fileadmin/...WebArticle.pdf
Old May 4th, 2012, 05:01 PM   #4
03hemisilver
Looking at the leveling kits being 2, 2.5, and 3" I think you'd be fine as-is.
Old May 4th, 2012, 05:11 PM   #5
OldManGrand
i hope so, just hate the nose high look. a few of the f-150 forums had people saying it looks like it sits high, but maybe it's just cause the wheel opening are larger?
Old May 4th, 2012, 05:23 PM   #6
03hemisilver
I would think with all the weight up front, it will settle after a short time. Maybe go "middle" height and not "max"
Old May 4th, 2012, 08:08 PM   #7
OldManGrand
i was debating that, maybe set it to the 3rd groove rather than the 4th, but if i run the wheels and tires i am planning, the way these have to be adjusting requires breaking them down and re-installing.
Old May 5th, 2012, 07:14 PM   #8
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
leave it nose high. It'll look as if your going fast!
Old May 5th, 2012, 07:38 PM   #9
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Www.f150online.com for all you need to know about f150's
Autospring add-a-leaf for the rear...
Old May 6th, 2012, 12:50 AM   #10
OldManGrand
^thanks I belong there, but to be honost they are not very helpful and more than a few are not all that knowledgeable, and a lot of them don't even use their trucks for anything other than the street. Sorry for the rant but I just got annoyed with that forum. I'll stick to greatlakes4x4 lol.
Page generated in 0.30199 seconds with 53 queries
