2004 Cargo Express custom enclosed car hauler - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2012, 06:17 PM   #1
pso728
pso728's Avatar
Default 2004 Cargo Express custom enclosed car hauler
Up for sale is my 2004 Cargo Express 20' Special Touring Edition custom car hauler/trailer. Used by former owner to haul around the Cobra to car shows. Ive used it for a couple years for camping and hauling ATV's. It is half-ton towable. Comes with load distributing hitch.
Exterior
Load distributing hitch with electric jack. Dual axle 5200lb per axle for 10,000 GVWR. Has two sliding screened windows on each side wall and an exterior quartz light. Has a 12' wide Dometic canopy that works as is but the canopy fabric could use replacing. There is an exterior locking generator compartment as well. The exterior is white with semi-smooth exterior panels and a 24" diamond plate stone guard up front. It has rear beaver-tail spring assisted ramp door and 48" side door. There are two roof vents and they are set up for AC service with bracing and wiring. The tires are all in decent shape and the trailer has electric brakes. Has decals on the back door that can be taken off if wanted.
Interior
It has L-shaped cabinets up front with plenty of storage space underneath for storage. Has 30 amp service with several outlets inside. Has a marine battery and battery tender and and cord to plug in and run everything or run it off battery. There are two small lights inside as well as two large shop type florescent lights. The walls are covered in white vinyl covering. The floor is covered in diamond plate and there are D-rings and Pingel chock mounts for hauling cycles and tying things down. The walls also have D-rings and e-track for securing items. The e-track also extends to behind the cabinets interior and above the cabinets for securing things. Mounted on the floor just inside the cabinet is a Warn 2500 S winch with controls from winching a vehicle in. Mounted on the top of the cabinet on the corner is a Craftsman vise for the extra hand for fixing things. There is a recessed area in the floor for the 2 ton jack and cribbing for changing tires.
I am the second owner and the original owner had the trailer customized for the car shows by TechWorks Trailer Conversions. I've owned it since 2008 and I am looking to sell as I now have property up north and no longer need to haul stuff back and forth.
Measurements are as follows; it is 6'10" interior height, 6'10" width between the wheel wells, 14'8" from the back door to the start of the cabinets.
Asking $5500 firm.
Call or text for more pictures. Kevin (2 six 9) 2 zero 7-6959
ID:	92185   Click image for larger version
pso728 is offline   Reply With Quote
Page generated in 0.23322 seconds with 27 queries
