Need help: (video) is my lock right too sloppy? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 2nd, 2012, 06:22 PM   #1
Yotabalt
Locked In
Yotabalt's Avatar
Default Need help: (video) is my lock right too sloppy?
Ok so, I just put my locker in, Toyota v6 diff, went by the books on this, back lash was right on, left the thrush washers in like Richmond said to do, but when its not in gear it seems loose, (first video)
It seems less sloppy when Its locked and in gear. And ratchets like its supposed to. Just need a second an third opinion. Any help is appreciated.
Yotabalt is offline   Reply With Quote
Old May 2nd, 2012, 06:37 PM   #2
Yotabalt
Locked In
Yotabalt's Avatar
Found part of the problem, the brakes aren't bolted up against the hub (rims are wrong bore and don't sit on the drum)...that made it much less noisey, and was much more tight.
Tags
locker, sloppy, toyota
Page generated in 0.19402 seconds with 29 queries
