Jeep YJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2012, 09:55 AM   #1
rangell
Ma' Meatloaf
rangell's Avatar
Default Jeep YJ
I have a extended length YJ frame, title and vin plates. $100. I had cut the frame just in front of the rear riser, and welded in a piece to make it the length of a Unlimited TJ.
rangell is offline   Reply With Quote
Old May 11th, 2012, 05:20 PM   #2
rangell
Ma' Meatloaf
rangell's Avatar
Default Pictures
Pictures of frame
Old May 11th, 2012, 07:05 PM   #3
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I'm interrested shoot me your number (PM)
CHEVYRCKS is offline   Reply With Quote
Old May 13th, 2012, 06:31 PM   #4
Zookini
Zookini's Avatar
I do not need the frame but would be interested in the title/vin number for my current project. lem me know if chevyrocks doesn't need these.
Zookini is offline   Reply With Quote
Old May 13th, 2012, 06:46 PM   #5
rangell
Ma' Meatloaf
rangell's Avatar
I don't believe he wants the title, so $50 the title and $50 for frame will work for me.
Old May 14th, 2012, 06:36 PM   #6
19602
Condtion of the frame and is it for 6 or 4 cylinder
19602 is offline   Reply With Quote
Old May 14th, 2012, 07:59 PM   #7
rangell
Ma' Meatloaf
rangell's Avatar
There are a few spots that I have cut out and not replaced. Not as bad rust issues as most YJ's. Don't know if it's for a 4 or 6.
Old May 15th, 2012, 10:50 AM   #8
rangell
Ma' Meatloaf
rangell's Avatar
top
Old May 16th, 2012, 12:22 AM   #9
19602
Can you find out what engine was in it? May be interested if it was one of the 6 cylinders.
Old May 17th, 2012, 07:11 PM   #10
rangell
Ma' Meatloaf
rangell's Avatar
Old May 18th, 2012, 05:10 PM   #11
rangell
Ma' Meatloaf
rangell's Avatar
Old May 18th, 2012, 05:11 PM   #12
Why YJ?
Don't be a wuss... HIT IT
Why YJ?'s Avatar
Just out of curiosity, was there any difference between frames? The only thing I can think of that would be different is the motor mounts.
2005 LJ comp cut, 1 tons, etc...
Paul
www.teamhodges.com
Why YJ? is offline   Reply With Quote
Old May 18th, 2012, 07:37 PM   #13
rangell
Ma' Meatloaf
rangell's Avatar
I do not know the answer to either question.
Old May 21st, 2012, 05:28 PM   #14
Amcjeeps
Amcjeeps's Avatar
As far as I know, the only difference between frames is the location of the motor mounts. I put a '91 4 cylinder frame under my '92 6 cylinder.
Amcjeeps is offline   Reply With Quote
Old May 22nd, 2012, 05:15 PM   #15
19602
You are correct, the only difference between the frames is where the motor mounts are placed. 4.0 only works on a 4.0 frame unless you cut the mounts off and re-weld them.
Old May 22nd, 2012, 05:17 PM   #16
19602
4.2 mounts are also mounted in the same spot as the 4.0's mounts.
Old April 17th, 2013, 04:53 PM   #17
rangell
Ma' Meatloaf
rangell's Avatar
ttt
Page generated in 0.37637 seconds with 74 queries
