I need axle help! - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2012, 10:01 PM   #21
Wramblerguy
Wramblerguy's Avatar
Originally Posted by tvandyck7 View Post
Yes. That is if you can match it up. If you have a 4.0L, more than likely you have a 3.07 ratio. I don't think 8.8's were produced with that ratio. You can find 3.55, 3.73, and 4.10's all day long though. Your easiest and best bet would be to replace the shaft. You can get an 8.8, but you then have to set pinion angles and weld perches, rework brake lines, rework the parking brake, and weld your shock mounts. You also have to adapt your driveshaft to flange mount. You might get a complete rearend for $2-300, but you'll have $750 in it before you know it.
The 8.8 is the way to go though if you are building up.
good luck finding a stock 89 yj with a 4.0L
Page generated in 0.17507 seconds with 26 queries
