I need axle help! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2012, 12:09 AM   #1
nextcoatings
NextCoatings
nextcoatings's Avatar
Default I need axle help!
I have a 1989 Jeep wrangler that i have been building sence i was 16. It was and is my first "car". I bent my rear drivers side axleshaft and idk if i should do an upgrade or replace just the axleshaft. If i went with an upgrade i wouldn't know what to look for and if i replaced the axleshaft i could be getting in over my head while im still trying to save/pay for college. I could use some advice on what the best way to go and keep the front axle and same bolt pattern.
nextcoatings is offline   Reply With Quote
Old April 30th, 2012, 12:14 AM   #2
boggin-machine
boggin-machine's Avatar
axle shafts are cheap as well as a complete rear end. replacing an axle shaft is as easy as pulling off the tire. pushing the axle shaft inward, removing the diiff cover and pulling a single clip out. them pull the shaft out from the side after backing the brakes off.
pretty simple and takes no longer then half hour
Old April 30th, 2012, 12:34 AM   #3
nextcoatings
NextCoatings
is there an axle that would i cud swap with my d35 that would have a better gear ratio and not interfere with my front axle and that would have the same bolt pattern so i could also keep my rims? If so wheres the best place to find it or is there another truck it may have came stock on
Old April 30th, 2012, 12:52 AM   #4
boggin-machine
im assuming your new to 4x4s. nothing is a bolt in swap that would be worth anything. it will cost more and not be worth your time. if you swap the rear axle with a different gear ratio and you will have to swap the front as well.
Old April 30th, 2012, 12:54 AM   #5
nextcoatings
NextCoatings
yes i am new. and i am learning very quickly that when you break things they cost alot of money to fix. thank you for your help.
Old April 30th, 2012, 01:12 AM   #6
boggin-machine
i would buy a matching rear end and just swap the shafts out. no worries man. let me know if you need anymore help
Old April 30th, 2012, 05:00 AM   #7
jaysusr
jaysusr's Avatar
I agree, a fun first project would be to swap an new shaft. Good to know how to do, cause if it happens on the trail, it sux to learn it then.
Old April 30th, 2012, 08:19 AM   #8
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Yjs do not use c clips they are retained by the bearing retainer.
Low still level replace axle shaft, if you have someone to help you and can weld get a explorer 8.8 and swap it out but this is not for a beginner
Old April 30th, 2012, 08:35 AM   #9
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Yj's do use c-clips. I think the early Dana 35s might not have though?
Old April 30th, 2012, 08:37 AM   #10
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
That's funny. My sons stock '91 YJ has a D35 with c-clips. Do some more homework.
Old April 30th, 2012, 08:38 AM   #11
BigBlockBlazer
Axle breakin' 101
Yes.
Old April 30th, 2012, 08:40 AM   #12
BigBlockBlazer
Axle breakin' 101
I have a set of spare rear shafts I'll sell you for $50 plus shippig.
Old April 30th, 2012, 09:00 AM   #13
Offroadian
seasoned
This is one of the first lessons to be learned.
If you use your 4x4 to play, it is an expensive hobby.
Not trying to dissuade you at all. Just warn you.
You're on the right track, asking for advice and learn quick.
Good luck.
Offroadian is offline   Reply With Quote
Old April 30th, 2012, 09:07 AM   #14
JeepInABox
In too deep
JeepInABox's Avatar
So, how did you bend it?
How much air did you get?
Old April 30th, 2012, 10:39 AM   #15
Jeepaholic
Jeepaholic's Avatar
Did some homework sir 87-89 were Non c clip so that would make me correct since op has a 89
Old April 30th, 2012, 10:39 AM   #16
bdd1469
bdd
bdd1469's Avatar
I would put a stock axle shaft in it for now,because it is cheap and easy.If you can save up a few hundred bucks buy a 8.8 ford rear axle from a explorer for a swap down the road.
The ford axle is the same wheel bolt pattern,almost the same width,and very strong.The newer ones come with disc brakes,many have a factory(pos) locker.If you have a 4cyl jeep it may have 410 gears,which are comon in explorers,6cyl may have 373 which are also common in fords.
Just search 8.8 in a yj,it's been done a million times. If you are going to keep your jeep,and wheel it,a 8.8 is one of the best mods on a tight budget.
Old April 30th, 2012, 10:59 AM   #17
BigBlockBlazer
Axle breakin' 101
Your comment says YJ's, not a specific year. They made YJ's for a long time.
Old April 30th, 2012, 11:04 AM   #18
BigBlockBlazer
Axle breakin' 101
Def 8.8 if your going to wheel it. Cheap and fairly easy.
Old April 30th, 2012, 01:45 PM   #19
nextcoatings
NextCoatings
if i did the 8.8 swap cud i keep my front axle as long as the gear ratios are the same?
Old April 30th, 2012, 01:58 PM   #20
tvandyck7
OlllllllO
tvandyck7's Avatar
Yes. That is if you can match it up. If you have a 4.0L, more than likely you have a 3.07 ratio. I don't think 8.8's were produced with that ratio. You can find 3.55, 3.73, and 4.10's all day long though. Your easiest and best bet would be to replace the shaft. You can get an 8.8, but you then have to set pinion angles and weld perches, rework brake lines, rework the parking brake, and weld your shock mounts. You also have to adapt your driveshaft to flange mount. You might get a complete rearend for $2-300, but you'll have $750 in it before you know it.
The 8.8 is the way to go though if you are building up.
tvandyck7 is offline   Reply With Quote
Page generated in 0.39926 seconds with 83 queries
