Mid Michigan Mud July 28th - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old April 29th, 2012, 07:54 AM   #1
scott2170
scott2170's Avatar
Send a message via AIM to scott2170 Send a message via Yahoo to scott2170
Default Mid Michigan Mud July 28th
At the birch run expo center
Gates open at 7
Tech starts at 830
Mud flies at 12
Registration is $20 per class
Admission is $8 kids under ten are free
100% driver payback
scott2170 is offline   Reply With Quote
Old April 29th, 2012, 08:03 AM   #2
scott2170
scott2170's Avatar
Old April 30th, 2012, 12:52 PM   #3
scott2170
scott2170's Avatar
Will have one if the biggest pits in Michigan
Old May 1st, 2012, 09:20 AM   #4
Unemployed Films
Capturing 4x4 Moments
Unemployed Films's Avatar
Cool pic even if I say so myself, yeah I took it last year at Eagle. Your event sounds cool, good luck and remember to check out unemployedfilms.com for you 4x4 action.
Unemployed Films is offline   Reply With Quote
Old May 1st, 2012, 10:15 AM   #5
scott2170
scott2170's Avatar
Come join us unemployed films
Old May 2nd, 2012, 04:11 PM   #6
scott2170
scott2170's Avatar
Ttt
Old May 3rd, 2012, 01:34 PM   #7
4-PLAY
4-PLAY's Avatar
NICE....lol
ps. make sure you bring some stickers to Jason's on the 19th
4-PLAY is offline   Reply With Quote
Old May 3rd, 2012, 04:19 PM   #8
Unemployed Films
Originally Posted by 4-PLAY View Post
NICE....lol
I will!
Old May 7th, 2012, 04:06 PM   #9
scott2170
scott2170's Avatar
Ttt
Old May 28th, 2012, 04:23 PM   #10
scott2170
scott2170's Avatar
$2000.00 bounty on all mod classes
35 class $100
40 class $200
44 class $300
Open class $400
Exotic class $500
Fastest pass of the day $500
And 100% driver payback on all classes
Old June 8th, 2012, 07:17 PM   #11
scott2170
scott2170's Avatar
we are working on adding a rail class
Old June 11th, 2012, 06:44 AM   #12
thefixer
thefixer's Avatar
Send a message via Skype™ to thefixer
facebook.com/MidMichiganMudRun you guys left out the "RUN" in your banner.
thefixer is offline   Reply With Quote
Old June 11th, 2012, 07:05 AM   #13
Cool parts peddler
Ironman Offroad's Avatar
Looking forward to being there with a big vendor booth!!!!!
Old July 1st, 2012, 02:57 PM   #14
scott2170
scott2170's Avatar
just a month away
Old July 6th, 2012, 10:45 PM   #15
IDIeselman
IDIeselman's Avatar
Could you post some general rules? Cuts? uprights? Engine location?
Old July 7th, 2012, 08:33 AM   #16
scott2170
scott2170's Avatar
. Stock Type: Classes #1 DOT Type Tires
1. Plates & Insurance must match vehicle Vin#.
2. 4x4 vehicles only.
3. Engine must be factory equipped to vehicle.
4. Motor must be in stock location.
5. Flat beds allowed.
6. No gutting or stripping.
7. Any carb or fuel injection (to factory).
8. No nitrous or exotic fuels.
9. Must pull at least 15" of vacuum at 800 RPM.
10. No relocation of drivetrain components. Lift-kits allowed.
11. No open exhaust, no headers and must have some sort of muffler.
12. No Boggers, Terra, Scoops, or Cut tires.
13. Must be DOT approved tires.
14. This class is for stock factory trucks ONLY!
Modified Rules: Classes #2 35 and under DOT Type Tires
1. Vehicles may enter twice per class with a different driver but can only place once per
class either longest run or fastest run.
2. Engines are not to exceed 500 cubic inches
3. Stripping & gutting allowed.
4. Body and frame must be production made. Flat beds allowed.
5. Naturally aspirated- no nitrous- no exotic fuels (bottle must be removed).
6. Axles must be within 6 inches of center of wheel wells.
7. DOT type tires only, no cuts, paddles or tractor tires.
8. Must have approved driveshaft loops.
9. Suspension must be comparable to stock type (lift kits okay). No adjustable coil-overs,
unless factory equipped.
10. Engines must maintain harmonic balance to centerline of front axle not behind.
Modified Rules: Classes #3 40 and under DOT Type Tires
2. Any motor and drive train combination allowed.
Modified Rules: Class #4 44 and under DOT Type Tires
1. Engine, body, and chassis open.
2. DOT type tires only, no cuts, paddles or tractor tires.
3. No nitrous or injected alcohol (bottle must be removed).
4. Adjustable coil-overs acceptable.
5. Must have approved driveshaft loops.
Modified Class #5 any size
1. Engine, body & chassis open.
2. Tire Size open. Cuts allowed. No paddles or scoops.
3. Any fuel naturally aspirated. Fuel injection ok No Nitrous. No Blowers.
4. Must have approved driveshaft loops.
5. Adjustable coil-overs acceptable.
Modified class #6 Run What Ya Brung
2. Tire Size open. Cuts allowed, Paddles or scoops ok.
3. Any fuel naturally aspirated. Nitrous ok . Blowers ok.
Old July 7th, 2012, 08:34 AM   #17
scott2170
scott2170's Avatar
* Required Equipment (all classes included) *
1.All classes must have seatbelts. Exotic classes must have a minimum 4pt. Harness.
2. A secure permanent hitch capable of accepting a 3/4" pin clevis at the rear and also at the front, if wishing to be pulled forward in the event of a full run. No hanging chains or cables. If your hitch fails, while being pulled back "you will be disqualified". Driver or crewmen will be required to rehook cable.
3. All vehicles must have a minimum of a fully charged 2.5-lb fire extinguisher with gauge in reach of the driver while belted in.
4. All drivers shall have full coverage racing type helmet. Snell 85 rated for Exotic Class.
5. All drivers must wear shirts, long pants and shoes during competition. No sandals or flip-flops.
6. Drivers of vehicles using exotic fuels, such as alcohol, must wear a full fire suit with head sox, boots and gloves.
7. All vehicles must have brake system capable of stopping the vehicle in a safe distance. All stock classes must have 4 wheel brakes.
8. Hood may be cut to allow for headers or induction system.
9. Carburetors must have flash shield or air cleaner. No air-intake thru drivers compartment.
10. All batteries must be securely mounted. Those that are mounted outside engine compartment must be completely enclosed.
11. All open bodied vehicles must have foot restraint on the drivers side to keep drivers foot from slipping outside the vehicle.
12. Inner fenders are required to protect area from radiator to front of engine block.
13. Full firewalls and full floorboards are required for all classes.
14. Whip antennas and tow bars must be removed for competition.
15. Any open or soft top vehicle with glass removed, must have 4 point roll cage, securely mounted to frame.
16. Every vehicle must have an engine kill switch within reach of the driver while he/she is fastened securely in harness or seat belt.
17. All relocated fuel tanks must be protected from collision and properly secured.
18. All vehicle fuel systems must have lines and pumps located outside drivers compartment and be vented below the floor of the vehicle unless equipped with factory vent or rollover valve.
19. All vehicles are required to have a working neutral safety switch.
20. The running gear of each vehicle will be inspected to verify the safety of such critical parts as steering, brakes, welds, tires, and body conduction, ect.
21. All vehicles must be race ready for tech inspection. No passengers permitted.
22. All vehicles in Modified and Exotic classes must have driveshaft loops on any shaft over 12" in length. Must be made of 1/4" x 1" steel or equivalent, located in the middle of the driveshaft or 6" from each end.
23. All vehicles must maintain four wheel drive in all classes. This means truck must have four wheel drive on the starting line.
24. All chain drives must be enclosed in all classes.
Old July 7th, 2012, 08:35 AM   #18
scott2170
scott2170's Avatar
we have also added a class 7 Tractor tires
only rule for this class...you must have four tractor tires on vehicle
Old July 8th, 2012, 04:21 PM   #19
thefixer
thefixer's Avatar
TTT... This should be a damn good time...
Old July 20th, 2012, 07:19 AM   #20
scott2170
scott2170's Avatar
Bump it's only a week away
Page generated in 0.49632 seconds with 83 queries
