want to build a yj - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 26th, 2012, 10:56 AM   #1
codyjames
codyjames's Avatar
Default want to build a yj
After I sell my bronco I'm looking to build a yj or cj I want to swap in half or 3/4 ton axles and do a soa I only want to run 35-38s my questons are what will I have to do to the transfer case with the added height (never built a jeep) also I was looking into the advanced adapters for a 350 swap and I was curious if anyone else has done that on this site keep in mind I will probly won't ever do any rocks with it
codyjames is offline   Reply With Quote
Old April 26th, 2012, 12:22 PM   #2
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
No rocks and 35's = use an exploder rear axle and stock d30 front axle on a yj.....
T-case = do an sye to it.
Biggest thing is learning what you need to do for a soa lift.
Lots of people use AA to put sbc's in. There are tons of options..... spend more time reading..
RIP FULLSIZE4LIFE
Old April 26th, 2012, 03:42 PM   #3
codyjames
codyjames's Avatar
The dana 30 will hold up to 35s
Old April 26th, 2012, 03:46 PM   #4
Why YJ?
Don't be a wuss... HIT IT
Why YJ?'s Avatar
If you leave it open and have a conservative right foot you should be fine. I wheeled for a year with 37's on my open Dana 30 with no problems. Now that I have 60's I am not as easy with the gas.
2005 LJ comp cut, 1 tons, etc...
Paul
www.teamhodges.com
Why YJ? is offline   Reply With Quote
Old April 27th, 2012, 08:22 AM   #5
mudrunner456
mudrunner456's Avatar
I run 36's on my tj on the stock dana 30 with it locked and still no issues. And i dont do much for rocks but im not easy on it.
mudrunner456 is offline   Reply With Quote
Page generated in 0.18461 seconds with 38 queries
