2 time award winning Project "YJ-8 Wrambler" - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 10th, 2013, 09:18 AM   #61
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
damn kid, you take forever!!!
Old January 10th, 2013, 11:00 AM   #62
Wramblerguy
Wramblerguy's Avatar
Yes I know motivation has been low the past month
3rd generation jeeper
Old March 31st, 2013, 03:31 PM   #63
Wramblerguy
I haven't updated this in a long time but I have been slowing working away at it
I got my knuckles machined and assembled with synergy ball joints
And put on the housing
I got the rest put back together and painted I changed the 7/16" studs to 1/2" and used warn premium lock outs
I still need to get some tube for my steering
Old March 31st, 2013, 03:34 PM   #64
Wramblerguy
I also have worked on the motor a bit
I replaced my engine harness and installed a performance ignition
Something missing here
It's back together and running now and my buddy is coming over today to help my finish it up
Old March 31st, 2013, 06:28 PM   #65
pitbull2332
pitbull2332's Avatar
It's back together and running now and my buddy is coming over today to help my finish it up[/QUOTE]
I dont see the supercharger on there yet. What gives, you have 1 week to get the axles and supercharger in it what gives. Looks like I will win the bet
pitbull2332 is offline   Reply With Quote
Old March 31st, 2013, 07:54 PM   #66
Wramblerguy
Axles are going in Tuesday so bam
Old March 31st, 2013, 08:02 PM   #67
Wramblerguy
Default Project "YJ-8 Wrambler"
Tonight I finished up my disk brake brackets in the back
We ground down the pads and calipers as much as we could to move it all farther in to help with the 15"wheel clearance
So the rear end is done except for brake lines and a vent
This weekend I went and got some Chevy spring plates for the u-bolt flip in the front, I cleaned them up and the one on the passenger side will work perfect but the drivers side is either getting heavily modified or something different but for $8 you can't go wrong
Old April 2nd, 2013, 01:41 PM   #68
Wramblerguy
Last night I got my tie rod tacked together and mocked up
I also started the tear down
I got the front axle all unhooked and ready to come out tonight when there is some people to help me pull it out
I also started on the back I just have u bolts and shocks left
Old April 2nd, 2013, 09:55 PM   #69
Wramblerguy
Tonight was a good night we got the old axles out and the new axles in
Rear perches still have to be welded after pinion angle is set
Front axle is in with the u-bolt flip and springs out boarded
Drivers side is going to require some fab
Shock mounts for both axles and a front drive shaft and It should be ready
Old April 3rd, 2013, 05:24 AM   #70
T&L81CJ5
T&L81CJ5's Avatar
damn all dizzy now trying to look at the picts upside down....
T&L81CJ5 is offline   Reply With Quote
Old April 3rd, 2013, 06:20 AM   #71
Wramblerguy
They are the right way on my phone. weird
Old April 3rd, 2013, 06:33 AM   #72
little_yj_95
little_yj_95's Avatar
Why are u doing spring over in the rear and spring under in the front?
little_yj_95 is offline   Reply With Quote
Old April 3rd, 2013, 07:30 AM   #73
Wramblerguy
That is how we did it originally
Spring over is cheaper and flexier but not as stable as spring under so we did spring under in the front to keep the stability
There is no swaybar or track bars and it is still very stable on the road while staying flexy offroad
Old April 3rd, 2013, 07:34 AM   #74
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Looking Good
Old April 3rd, 2013, 07:53 AM   #75
T&L81CJ5
T&L81CJ5's Avatar
then turn your phone over and pst them again........
Old April 7th, 2013, 12:58 PM   #76
Wramblerguy
So rear axle pinion angle set and perches welded
Shock mounts welded on and shocks on including a new one to replace one that was junk and old drive shaft still works good and is bolted in
Front axle is bolted in, drivers side spring plate took some creative fab work but it turned out good
Shock mounts made and welded on and shocks bolted up
Old brake lines drilled out for slightly larger banjo bolts and bolted on
I got the 33s on it and it looks prety good
It gonna look even better with 35s
I still need to figure out brake lines in the back, make a drag link and figure out/ream a pitman arm
And my master cylinder should be here today
Old April 21st, 2013, 08:49 PM   #77
Wramblerguy
I finished up the rear brake lines, I ended up using 79 el camino brake lines in the rear and it turned out nice
Master cylinder install went prety good
We eliminated the splinter block and redid some brake lines
I had alot of trouble getting it to run because my new coil turned out to be bad
Today I got it finished up and put about 50 miles on it today
Went over and got my tires mounted up today too at pitbull2332s and I think they are gonna look sweet he also had a front cv shaft that should work for me
Old April 22nd, 2013, 06:22 AM   #78
KennyOffroad
Looks Good !
Old April 22nd, 2013, 11:36 AM   #79
T&L81CJ5
T&L81CJ5's Avatar
So it was the new coil that was disfunctional?
Glad you got that figured out.
Now if some clown would get his CJ off the lift you could mount those bad boys up!
Heading over later tonight to make that happen......
Old April 23rd, 2013, 10:46 PM   #80
Wramblerguy
Front cv shaft was too short so we shortened the old one
Turned down a sleeve and pressed it in both sides
It turned out great
I did a few back yard poser shots with the 33s
Then put the 35s on and it looks bad ass
So it only needs a good drag link made but the temporary one will last through the shake down run this weekend, I can't wait
Page generated in 0.49284 seconds with 84 queries
