2 time award winning Project "YJ-8 Wrambler" - Page 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 13th, 2014, 08:53 PM   #201
Wramblerguy
Wramblerguy's Avatar
No, we have had this trip planned for a while
I try to go to jeepin for a cure every year
3rd generation jeeper
Old May 13th, 2014, 08:54 PM   #202
bigdogwaggy
bigdogwaggy's Avatar
Just have to catch up next time ! Have some fun!
Sent from my DROID RAZR HD using Tapatalk
bigdogwaggy is offline   Reply With Quote
Old May 13th, 2014, 09:10 PM   #203
Wramblerguy
For sure hopefully I can come out next time I have a fairly full summer
We will definately have fun
Old May 19th, 2014, 10:24 PM   #204
Wramblerguy
Had an awesome day at r&v Saturday
Ran hump trail for the first time
I've officially ran the whole park now
I'm thinking of doing an exo type cage instead of one that goes through the hard top now
This way I can protect the hard top as well as the windshield frame I've smacked them both too many times
Washed the jeep today for the first time since last fall probably
Old July 20th, 2014, 02:28 PM   #205
Wramblerguy
Went to bundy yesterday and was following a buddy's rzr 1000 all day annnnnnd it got me here
So I don't think I need to do that again
It was scary but a little tug from a ranger and I was good
Overall it was a good day
Only bad is I want a rzr now that thing is crazy
Old July 28th, 2014, 07:35 PM   #206
Wramblerguy
Heard a noise in the rear end this weekend
Turns out my pinion bearing is smoked somehow... Hopefully get it fixed in time for silver lake this weekend
Got it all tire apart tonight should be a simple deal....should
Old July 29th, 2014, 09:26 PM   #207
Wramblerguy
well upon further investigation the pinion nut must of loosened up because the bearing seemed fine and tightened right back up. i used some lock tight this time
pinion is undamaged tho with just a slight polish on the end of the the from contacting the locker
got it partially back together tonight ill finish it up tomorrow and get it ready for the dunes this weekend
Old August 14th, 2014, 03:44 AM   #208
Wramblerguy
exo cage on ma mind!
Old August 28th, 2014, 09:38 PM   #209
Wramblerguy
231 rebuild kit and 2 low kit should be here tomorrow
i already have a 1.25 chain and sprockets so all i need is a 6 pinion planet and then its tear down time
badlands trip planned in 3 weeks
these might happen before then, we will see
http://www.4wd.com/Jeep-Tires-Jeep-T...n=GDY750712326
if money and time works out that is
Old September 16th, 2014, 03:42 AM   #210
Wramblerguy
Jeep took a beating last weekend at the dunes
Hopefully the check engine light goes away
Threw it on the lift yesterday and found a few issues
First was this
Luckily the inner shaft is unharmed
So I got the spare installed but found a bunch of water in the hub so that took longer to clean up
Might have a outer shaft coming tomorrow and I ordered another joint
Also @Jimmysjeep is gonna bring my some full circle clips so hopefully I don't have this problem again
Also found a tre that loosened up and was contributing to the death wobble
Exhaust also separated last weekend
At some point in the last few trips I managed to smash my oil pan
Also started in on the very broken center pin I've known about for a while
Bushings are also very worn
So new center pins, bushings and degree shims along with the tightened tre should fix my death wobble and make it drive like a dream again #fingerscrossed
Crunch time for badlands this weekend
I'm also picking up a tcase this week to build up
Old September 16th, 2014, 11:42 AM   #211
powerranger33
powerranger33's Avatar
Saw you up at the dunes this weekend. Went by when you were pulling someone out of the trees
powerranger33 is offline   Reply With Quote
Old September 16th, 2014, 12:41 PM   #212
Wramblerguy
Ya I did my good deed for the day lol
They were having trouble and none if them had a winch so I did the nice guy thing
I got to rewind my cable tho lol
Old September 16th, 2014, 06:17 PM   #213
ATVLIFESTYLE
ATVLIFESTYLE's Avatar
good to know I'm not the only one that breaks stuff at the dunes. Why didn't you stick around till dark?
ATVLIFESTYLE is offline   Reply With Quote
Old September 16th, 2014, 07:48 PM   #214
Wramblerguy
Default Project "YJ-8 Wrambler"
Ya alot of this stuff has been a while coming lol
I watched you guys from test and followed you (kinda) when you drove by
I was with a group if people and just never split off
Old September 16th, 2014, 08:03 PM   #215
Wramblerguy
Add a couple of uncooperative u bolts and the 2 9/16s bolts to the list as well
I might buy a new muffler too since this one is junk
It's only money right
Old September 18th, 2014, 10:48 PM   #216
Wramblerguy
Buttoned it up today
I welded the exhaust together too and got rid of some clamps, that was nice.
And a new muffler
Thing handles like a sports car now!
Oh and the center pin that wasn't broke was on the end if it's life it had the staircase bends in it
Prety happy with it now
On a side note I should probably build a new front drive shaft this one is pretty whipped
Old September 18th, 2014, 10:50 PM   #217
Wramblerguy
Oh and I'm on track for the bad lands, jeep is ready
I just have to weld some d rings back on the trailer tomorrow and load everything up
Super excited haven't been to the bad lands in yeeeeeaars
Old September 26th, 2014, 02:03 AM   #218
Wramblerguy
Had a blast at the badlands
Had a early failure where a tab on the alternator wiring broke
But the spare I brought had the wiring on it
So a couple butt connectors later from generalyota and we were back on the trail
Post trip inspection I think I smashed the oil pan some more so that's probably next on the list to fix
Also found this
Small crack above factory weld by steering box
And I already knew about this one
So some frame playing to the list too
Next event is the timber ridge crawl but thats going to be very mild so no worries there
Savin up for tires again and hoping 4wd has them when I'm ready
Old October 12th, 2014, 09:50 AM   #219
Wramblerguy
New tires
Old October 12th, 2014, 09:52 AM   #220
bigdogwaggy
Gonna have to get them out and try them!
Page generated in 0.40534 seconds with 84 queries
