10 bolt diff help please! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 22nd, 2012, 10:18 AM   #1
camccardell
tiger blood
camccardell's Avatar
Default 10 bolt diff help please!
I am working on a 97 burban with a 10 bolt rear axle.
Thing has over 200k on it.
My question pertains to pinion rotation.
With the truck on the ramps, with the parking brake on, I can grab the yoke and rotate it I would say around 10 degrees back and forth. I think that is a bit excessive. Is that normal, or is that a good indication that it needs pinion bearings?
I would rather not tear into this axle, as the rear diff bolts and pan are all rusted to hell. Surely a bolt or 2 would break off and I do not want to drop the fuel tank to fix em.
Ideas?
specs on this, or a way to test it?
Old April 22nd, 2012, 10:37 AM   #2
bdd1469
bdd
bdd1469's Avatar
Pinion bearings rarely fail unless you run it out of oil,obviously if you have a locker or bigger tires they go thru more abuse.Usually when the pinion is loose the rearend will whine or howl when you let of off the gas at speed.
Spinning the pinion with the park brake holding is giving you all the slop in the rearend,from the backlash,through the spider gears,and even the brake pads can rock a little.
Without pulling the cover you cant do much.The bolts shouldnt break ,if you pound a 1/2 socket on the rusty bolts and remove them with a impact.
I would guess that most of your slop is in the spider gears/cross pin.The only way to find out is to pull the cover and inspect them.Once the cover is off you can check backlash with a dial indicator to see if bearings are gone.
Old April 22nd, 2012, 09:17 PM   #3
camccardell
tiger blood
Thanks,
Gotta drop the tank to do this, dammit all to hell.
As far as the oil goes, it took almost a quart to get it to spit back out at me, so I think she was a little low. The pinion seal is shot, and there has been some leaking it looks like.
Old April 22nd, 2012, 09:24 PM   #4
bdd1469
bdd
bdd1469's Avatar
You shouldnt need to pull the tank.Put jack stands under the frame and un hook the driveshaft,and shocks on one end,the rear axle should drop enough to service it.
Page generated in 0.17645 seconds with 35 queries
