1998 dodge ram wont start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2012, 08:28 PM   #1
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Send a message via AIM to dakotaguy1
Default 1998 dodge ram wont start
Hi i have a 1998 dodge ram with the 5.9 that wont start. I just swapped in a different motor and got it all hooked up and it cranks over but will not start. Also the fuel pump is not kicking on and i have no spark. I noticed on the dash the odometer is blinking,the security light is on, air bag light, and seat belt light are on. also i cant remember if it beeped like this before but when you first put the key in and turn it it beeps 6 times then stops then 4 more times after that then 2 after that. I did the check through the odometer and the codes 920, 921, 940, 950, and 999 come up. I think it could be the ECU but before i do that does anybody have any other ideas? thanks
dakotaguy1 is offline   Reply With Quote
Old April 20th, 2012, 12:14 PM   #2
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
nobody
Old April 24th, 2012, 12:15 AM   #3
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
top
Old April 24th, 2012, 08:16 AM   #4
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Sounds like ECU to me... Good luck
Old April 24th, 2012, 08:41 AM   #5
JeepInABox
In too deep
JeepInABox's Avatar
Did you use the old flywheel or the one off the new engine? Sounds like bad or no crank signal.
Old April 24th, 2012, 03:34 PM   #6
rammanriley
rammanriley's Avatar
Figure out why the Security light is on and go from there.
rammanriley is offline   Reply With Quote
Old April 29th, 2012, 02:11 AM   #7
buddyayres
DAAM Racing
buddyayres's Avatar
Send a message via AIM to buddyayres Send a message via MSN to buddyayres Send a message via Yahoo to buddyayres
i don't have an answer for you but go over to dodgetalk.com and ask you question over their. they have so many people that are all about those second gen rams. thats where i go when i have a question.
buddyayres is offline   Reply With Quote
Old April 29th, 2012, 02:35 AM   #8
isuzutruggy?
Kreepy Krawlerz Off Road
isuzutruggy?'s Avatar
Sounds like cps
isuzutruggy? is offline   Reply With Quote
Page generated in 0.30541 seconds with 47 queries
