95 f150 stalled and wont start!? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2012, 06:52 PM   #1
sluginxlt
tooweel or not tooweel
sluginxlt's Avatar
Question 95 f150 stalled and wont start!?
i have a 95 4x4 I6 5spd f150 with 190k that has always ran strong and the other day i crossed a bumpy intersection and it made her sputter and stall. I tried starting it a few times and had a really loud backfire. i then noticed when i would turn the key on i couldn't hear fuel pump turn on. I called my brother to have him push me home with his bronco and when i got home and tried to start it i can clearly hear the fuel pump turning on and it will crank and crank but never start. changed the fuel filter and i turn key on with the filter disconnected to confirm it is pumping, i also depressed valve on fuel rail and confirmed there is fuel in the rail. Any body out there have any idea what could be wrong from these symptoms? Thanks in advance
sluginxlt is offline   Reply With Quote
Old April 18th, 2012, 08:10 PM   #2
firehawk
Live Action!
firehawk's Avatar
If you are satisfied it is not a fuel problem then check for spark.
I would still check the fuel pressure though to be sure it is adequate.
Air fuel and spark are what it takes for an engine to run. Could be a bad ground or other wiring problem.
Old April 21st, 2012, 11:07 PM   #3
Never_Evil
When you check for spark check your timing. The nylon timing gears may have given up the ghost.
Old April 23rd, 2012, 05:42 PM   #4
sluginxlt
sluginxlt's Avatar
i pulled the front plug and grounded it to check for spark and it has good spark. i also gave a few squirts of starting fluid down the throttle body assuming it should at least fire but that did nothing
Old April 24th, 2012, 12:06 AM   #5
booblinker
Sore and Tired 24/7
booblinker's Avatar
My 4.9 randomly stopped running, ended up being a sheared pin in the distributer gear.
Old April 28th, 2012, 09:36 PM   #6
eagle-eye
My 4.9 did the same thing, although mine ended up being timing gears. Check for compression. it may be different in different cylinders because the cam gear is broken and cam/lifters/valves are stuck and cant rotate. Get the steel cloyes gears and you will never have a problem again. pretty noisy though, but small price to pay for the ultimate in reliability.
eagle-eye is offline   Reply With Quote
Old April 28th, 2012, 09:55 PM   #7
MilwaukeeF350
Dan
Peek in oil cap and crank do you see rockers are moving or not.
Check with timing gun to see if timing is mess.
Page generated in 0.37625 seconds with 44 queries
