SOLD - 1998 Dodge Ram V10 2500 4WD Quad Cab Longbed - $4500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 16th, 2012, 06:45 PM   #1
PavementPounder
PavementPounder's Avatar
Default SOLD - 1998 Dodge Ram V10 2500 4WD Quad Cab Longbed - $4500
I don't have pictures of it in its current state, but it hasn't changed from the pics below other than being on tiny rollers. The wheels shown are still on it, just with low-profile tires. I have the center caps as well.
I will add more detail and current pictures next time I get to the storage unit, which is in Casco, MI. Here are the basics:
  • Original owner. Custom ordered it new.
  • 150k-ish miles
  • 488 V10, 47RE, 241DLD, D60 front, D70 rear.
  • 5.13's, Detroit locker in rear. Open front, CAD still worked last time I drove it.
  • Approx 9"-10" of lift. Fit the 40"x13.5"r17 MTRs below without issue for a few years and will stuff well.
  • Lift started out as a 7" Skyjacker Doubleflex with the dual front shock option (came with QA1 style kevlar-impregnated heims). Added a 2" BDS front levelling kit and performed a shackle flip in the rear to achieve the current stance and height.
  • Black with Mist Grey leather interior, still in good shape. Carpet was pulled when it got wet and decided to just leave it out. Never got around to lining the floor.
  • Vehicle is loaded and everything worked except for the CD changer that got wet. Hook up a new one and you're good to go.
  • A/C compressor assembly was replaced at the dealer circa 2009.
  • Vehicle has plenty of pinstripes, some surface rust at the bottom of the doors, some cracks in the windshield, and some damage to the passenger rear bed corner where I kissed a tree.
  • Trailready front bumper with Warn 16.5ti front-mounted winch. Hardly any usage because this shit did not get stuck.
  • Driveshafts currently pulled, but present.
  • New Die Hard Platinum 34/78DT (dual terminal).
  • Solid Steel steering box brace.
  • Convertor will drain back if it sits for a while. Only thing you have to do when that happens is put it in neutral for a few seconds after start-up and then drive. The valve can be replaced and info is readily available online.
  • Has 2" steel wheel spacers to accommodate the increased backspacing of the 2005 2500 rims that are on it, so you have some room to work with if you plan to swap rims on. I have the original wheels as well.
It has one problem keeping it from moving. It either needs a fuel pump or some troubleshooting on why the pump is not working.
I did a lot with this truck and could not kill it. Fix the fuel pump, throw some 40s on it, weld the front diff if you want, and go smash it into a tree or drive it through a lake. Truck went 70mph down the highway without issue. I even towed with it at that height.
$4500.
WILL NOT PART OUT. I AM NOT INTERESTED IN ANYTHING IN TRADE.
Sold.
PavementPounder is offline
Old April 16th, 2012, 07:19 PM   #2
chasetheface123
chasetheface123's Avatar
If I had the cash, It would be mine. GLWS and NICE truck!
chasetheface123 is offline
Old April 17th, 2012, 01:01 PM   #3
jeepjumper
Does not own a jeep...
jeepjumper's Avatar
What kind of mpg did it get?
jeepjumper is offline
Old April 26th, 2012, 07:35 AM   #4
PavementPounder
All original suspension parts included.
Old April 26th, 2012, 06:58 PM   #5
butcyh cassidy
butcyh cassidy's Avatar
that is the most gorgous ram i have seen in a while! if you change your mind on trades i gladly give up my burb.
butcyh cassidy is offline
Old May 3rd, 2012, 07:21 AM   #6
PavementPounder
Want to move it ASAP. This is the only thing making me hold on to my storage unit due to the door height required to store it. Price reduced.
Price will go up if I get to putting the driveshafts back in and buying tires to make it functional again.
Old May 7th, 2012, 10:34 AM   #7
PavementPounder
Now has a new Die Hard Platinum 34/78DT.
Old June 28th, 2012, 06:20 PM   #8
PavementPounder
Sold.
Page generated in 0.27923 seconds with 47 queries
