2gen body lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 10th, 2006, 10:07 PM   #1
zj kid
Vern
zj kid's Avatar
Send a message via AIM to zj kid
Default 2gen body lift
i have a 98 and want to do a 3" body lift on it
has anyone done this? what are things to look out for?
zj kid is offline   Reply With Quote
Old October 11th, 2006, 06:40 AM   #2
PavementPounder
PavementPounder's Avatar
Basically everything. Brake lines, steering shaft length, etc, etc. I would not do it and stick to suspension mods.
Old October 11th, 2006, 11:41 AM   #3
SS
Bananarama!
SS's Avatar
The only thing I liked about the 3" body lift on my 95 Ram was the amount of space it opened up under the hood for maitenance...
Go suspension lift.
-Jer
Old October 11th, 2006, 01:05 PM   #4
DodgeitRamit
DodgeitRamit's Avatar
If all you want is a little bit of lift and don't plan on going higher, for the same price of a body lift you can buy 2" coil spacers for the front, and a lift block or addaleaf for the back.
DodgeitRamit is offline   Reply With Quote
Old October 12th, 2006, 03:52 PM   #5
zj kid
Vern
zj kid's Avatar
well its going to be a street only truck...and i have a 3" suspension lift that i was gunna but on with the 3" body to run 37"s
Old October 12th, 2006, 10:33 PM   #6
PavementPounder
Use a spacer in the front and then flip the rear shackle on top of the 3" lift.
Old October 12th, 2006, 10:42 PM   #7
user name
keep your stick onthe ice
user name's Avatar
i have no hatered for body lifts. that said i wont go more than 2" on my own truck. i think the biggest problem would be the steering shaft. Are the brake lines coiled up by the master like the older trucks? if so they will most likely be fine.might want to make sure there is slack in any harnes that goes down to the frame. your bumpers will look gay if you dont bring them up with the body IMHO. just take a look along the between the body and frame think will that streach 3 inches.
body lifts make trany removal a lot easier because you can then kinda reach the belhousing bolts.
Old October 12th, 2006, 10:54 PM   #8
boggin-machine
boggin-machine's Avatar
dont you already have 37s on ur truck rob
Old October 13th, 2006, 10:34 AM   #9
zj kid
Vern
zj kid's Avatar
no i sold my 95 and got a 98 2500
Old October 13th, 2006, 11:30 PM   #10
sonic
sonic's Avatar
The best thing about putting the three inch bvody lift on a Ram is that there is no need for gap guards. I have one on mine and installed it with a friend in about 4 hours. You need to know how to weld to extend the 4x4 linkage and the shifter linkage. You dont have to do anything else with the brake lines. there is a few harnesses that you need to detach from the body but thats about the hardest part. I have had no problems as far as the body lift goes and my truck has been through some shit. I do however check the body bolts every now and then and I think that is important. I highly recomend it.
sonic is offline   Reply With Quote
Page generated in 0.23001 seconds with 53 queries
