10 bolt gear questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2012, 09:27 PM   #1
The-Sandman
Real jeeps are built...
The-Sandman's Avatar
Default 10 bolt gear questions
i have 10 bolt axles in my truck front and rear... pics here
help IDing 10 bolt axles and t-case - Great Lakes 4x4. The largest offroad forum in the Midwest
wanting to change the gears to 4.56 or 4.88
here is my truck info
80's style frame and drivetrain, motor is stock 350.....for now
current gears are something like 2.73 or 3.07....
I am running a 35x14.50x15 super swamper sx...
currently i only use 4 lo.... cause theres no power otherwise...
truck is being built as a dedicated wheeler... and will trailer it where ever it goes...
So my questions are.....
is 4.56 enough gear? should i go 4.88 or even bigger?
do i need to be worried about the gears fitting my carrier with the highway gears it has?
will the same gear work for both front and rear 10 bolts?
any good ideas where to buy? online preferred... dont want to drive 2 hours
should i get master install kits?
The-Sandman is offline   Reply With Quote
Old April 16th, 2012, 03:07 PM   #2
Cool parts peddler
Ironman Offroad's Avatar
I would suggest you go 4.88.
You will need carriers, so now is the time for lockers.
Master install kits are the way to go.
Use the high quality parts for best results.
Old April 24th, 2012, 01:28 PM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
See text in red below:
Originally Posted by The-Sandman View Post
i have 10 bolt axles in my truck front and rear... pics here help IDing 10 bolt axles and t-case - Great Lakes 4x4. The largest offroad forum in the Midwest
4.56 is "enough" but 4.88 gives you better low speed control and better crawl ratio.
No
Yes
www.jeeperz-creeperz.com
You'll probably want them rather than trying to use your old bearings
You won't need new carriers....
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old April 24th, 2012, 04:38 PM   #4
davidkassie
davidkassie's Avatar
I have 4.56 with 35" boggers, wish i had 4.88's. i have a strong motor but it still seems like its doggy in high range. good luck, lol.
davidkassie is offline   Reply With Quote
Old May 9th, 2012, 11:45 PM   #5
Ebrown
Ebrown's Avatar
I have 34 TSL and 3.73 auto trans with no problems
Ebrown is offline   Reply With Quote
Page generated in 0.48127 seconds with 39 queries
