help IDing 10 bolt axles and t-case - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2012, 09:30 AM   #1
The-Sandman
Real jeeps are built...
The-Sandman's Avatar
Default help IDing 10 bolt axles and t-case
hey,
i found a locker for a 10 bolt, 28 spline chevy axle... for $100
my truck is built from multiple trucks....so i have no idea what i have.... bought it this way... just about everything looks custom or modified
71 cab front clip...
84 step side box(i changed this from a 71 fleet side)
78-81 350 engine with passenger side dipstick
3 speed auto.... not sure if 350 or 400
frame beleived to be a 71.... appears modified all over the place... maybe it was a 71 2wd frame.. that is what i was thinking
no idea on what axles or t-case is.... just that it is 6 lug so it is a half ton
so i got on line and compared pics to my axles and T-case... it appears i have 10 bolt axles front and rear.... but are the 28 spline or 30 spline? any way to tell without tearing it apart?
http://www.jegs.com/p/Powertrax/Lock...45940/10002/-1
and i think my t-case is a 203 or 205.... it is a steel case.... 4wd shifter is for a 203, but it is so sloppy cant tell if they is 4 (for 205) or 5 (for 203)shift positions
http://www.chuckschevytruckpages.com/drivetrains.html
the main point to all of this will the locker fit my truck? i hate not knowing what everything is
The-Sandman is offline   Reply With Quote
Old April 12th, 2012, 09:34 AM   #2
tonkatruckon44s
tonkatruckon44s's Avatar
post a picture of the actual axle and of the tcase and we can help with both
tonkatruckon44s is offline   Reply With Quote
Old April 12th, 2012, 09:49 AM   #3
The-Sandman
i have a drivers side speedo cable.... so it must be a NP203 full time Tcase.... is that a strong case? i always heard you want the np205
here is some pics
front axle
tcase
rear axle
Old April 12th, 2012, 04:43 PM   #4
tonkatruckon44s
10 bolt front 203 tcase
Old April 12th, 2012, 05:44 PM   #5
red87chevy
red87chevy's Avatar
Looks like all junk ill give ya 400$ for it!
red87chevy is offline   Reply With Quote
Old April 12th, 2012, 05:50 PM   #6
Andy456123
Guest
Looks to me like a 10 bolt rear too. To be sure on spline count, I think you would want to pull the diff cover and see if you can either see the end of the axles in the carrier to count splines, or see the valleys in the side gears and count them.
Andy456123 is offline   Reply With Quote
Old April 12th, 2012, 06:07 PM   #7
boggin-machine
boggin-machine's Avatar
my pants fit very tight now that ive seen your truck!
Old April 12th, 2012, 06:23 PM   #8
The-Sandman
ha ha....$400 isnt close enough.... i have 2100 into so far
when its finished, i bet you wont think its junk... but there will also be a couple thousand more into it
trying to build a budget(ish)trail rig, that is also cool looking.... and not to put as much into it as my blazer... that i am afraid to breathe on
Page generated in 0.34119 seconds with 47 queries
