Smittybuilt Xrc Bumpers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 10th, 2012, 01:07 PM   #1
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Default Smittybuilt Xrc Bumpers
I've been bumper shopping lately for my dad's new tj, and we both like the looks and features of the XRC bumpers. However I know that Smittybuilt has a reputation of being Shittybuilt, and I was wondering if their build quality has come around or if they are still junk?
Old April 10th, 2012, 01:14 PM   #2
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
I like those XRC bumpers. But knowing somewhat of their rep, I may have mine custom built. I like the look of the stingers
Old April 10th, 2012, 01:56 PM   #3
mschaffer66
mschaffer66's Avatar
PM kristavsmichigan...
Old April 10th, 2012, 02:02 PM   #4
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
That didn't take long
Old April 10th, 2012, 02:21 PM   #5
mschaffer66
That's what she said...
Oh wait...
Old April 10th, 2012, 07:49 PM   #6
grnd93
grnd93's Avatar
have the src stinger and rear with swingout on my TJ. they look decent and are heavy as hell. I haven't bashed them on anything yet so I can't speak to the durability. My front I bought used and it was rhinolined since brand new. I did the same for the rear. the tire carrier is factory powdercoat and has held up fine for a year so far. The only thing I have had to do was replace the rub block on the bottom of the latch mechanism. from the factory it is abs plastic and snapped in half from the vibration. Had one made from nylon and it's holding up fine (they also send me a new plastic one under warranty).
grnd93 is offline   Reply With Quote
Old April 10th, 2012, 08:26 PM   #7
chasetheface123
chasetheface123's Avatar
I dont know about their bumpers, but they look pretty darn good. I can speak from their winches though. I have had nothing but great luck with mine, and I know firsthand their customer service is TOP NOTCH!
chasetheface123 is offline   Reply With Quote
Old April 10th, 2012, 11:39 PM   #8
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Do you have a pic of the broken plastic part? Your opinion on the latch/swing out. Do the frame mounts seem up to par? Also how does the over quality seem? Chincy, poor welds, good, bad, ugly? ect
Thanks
Old April 11th, 2012, 12:23 PM   #9
grnd93
grnd93's Avatar
Thanks
Welds seem ok to me...overall quality is fine. The latch for the swing out is pretty basic. If I had any complaint it would be the design of the swing out in general...nothing particularly bad about it, just would like to see some more strength in it.
The rear bolts to the rear crossmember in 8 spots, the 4 outboard ones use existing holes, the other 4 you have to drill. It also bolts underneath to the frame. Seems solid enough, and the hitch is supposed to be rated for 5000lbs. They include some plates to help spread the load where the crossmember bolts go, and you could always use frame tie ins to beef it up more. I'd have to say for the price it's a good deal.
In the pic the black one is the one that broke...had the white made as a replacement. It's just a rub block for the bottom of the swing out latch, but without it the arm can bounce around and come unlatched.
Old April 11th, 2012, 12:34 PM   #10
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Attachment 91364
Ok, that sound sufficient, especially for the price. How do you feel about sliding into a tree, or catching it coming off a rock with the tire carrier? That would be the main concern as it could crush the tub.
As for the plastic piece you had made, how much did that run you? And could you ever get another one made?
Old April 11th, 2012, 06:09 PM   #11
grnd93
grnd93's Avatar
ID:	91395Click image for larger version
ID:	91396If the carrier got banged into a tree it may do some damage, but I would imagine most on the market would as well. The bumpers themselves I would have no issue smacking them up against a rock or tree.
I had a friend make that part for me, so it was free...if I can catch him when he isn't out on the road I could probably get another. If you get the XRC it may not even use the same latch, I'm not sure what the differences are
In the first pic you see what I feel is the biggest downfall of their design. I would prefer a spindle/bearing setup, but of course that's more money.
The second pic is just a general pic of their latch. Pull the safety pin and lift up the lever. You can see the white run block under the lever. It keeps the whole thing from bouncing around too much.
One other thing you may consider if you use the SRC is welding block off plates over the ends. They come open from the factory so mud and salt can get inside. I make it a point to flush mine thoroughly when I wash it . It also made it easy to run wires for the 6 pin trailer plug that I mounted in the bumper.
Old April 17th, 2012, 07:50 PM   #12
zoomin0074
I have that rear bumper / tire carrier w/ 33" tire on it, the swingout part broke off the bumper because the spindle was only butt welded on.. I called customer service and they sent me out a new rear bumper with the spindle going all the way through.. The latch mechanism is crap and rattles like crazy, I had to fabricate a rubber piece to keep it quiet.. Oh yeah and my plastic block broke in 2 pieces had to make a new one of those also.. I am currently looking for an alternative latch setup.
zoomin0074 is offline   Reply With Quote
Old March 8th, 2013, 07:31 PM   #13
scaterbrain
pay attention to what?
scaterbrain's Avatar
I have the stinger and I can tell you there are some trees that regret it. Still looks great. H20 winch that has never given me grief.
scaterbrain is offline   Reply With Quote
Page generated in 0.29544 seconds with 63 queries
