1991 Cherokee- well built! - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Ebay / Craigslist / Auction Links
Ebay / Craigslist / Auction Links Find something interesting on ebay or a classifieds website? Share it here.
Old April 10th, 2012, 11:21 AM   #1
GMKLR50
Broke wheeler
GMKLR50's Avatar
Default 1991 Cherokee- well built!
http://detroit.craigslist.org/okl/cto/2942322512.html
This is not mine, it is my neighbors, I have not seen this jeep leave his drive way sense Nov. 2010, It is a very nice jeep!
1991 Jeep Cherokee XJ LTD - Crawler - $8000 (White Lake, MI)
Date: 2012-04-09, 10:15AM EDT
Reply to: mzpbq-2942322512@sale.craigslist.org [Errors when replying to ads?]
After not driving my Toy Jeep for nearly a year, I have finally decided to let her go. I have tried my best to describe all the goodies, but I'm sure I have missed a few trinkets. She has been garage kept since I have owned her. Originally purchased as a bone stock Cherokee, I have spent literally thousands of hours building it to concur any obstacle possible yet still be 100% street legal - She is NOT a trailer queen and has been driven to and fro. Everything has a purpose and works extremely well. Feel free to email me and I will respond with my number. Serious inquires only.
1991 Jeep Cherokee XJ - 152,000 miles
General:
100% synthetic lubricants used (Engine oil, front / rear diff, power steering and transmission)
35" Goodyear Mud Terrains w/ center lugs sipped, including full size spare -- 12k miles on tires
ARB Bull bar w/ WARN 9000 lb winch and 130watt IPF driving lights
Viair 550c on-board Air Compressor
Fire Extinguisher
Bushwacker extended fender flairs
Husky Floor Liners Front and Cargo area
Chassis Black / POR-15 / Rubberized undercoating to prevent rust
Chassis / Suspension:
10" Lift (Rubicon Express upper / lower control arm w/ chassis reinforcement brackets)
Suspension Droop Limiting straps
Rancho RS9000 Rear shocks relocated and reinforced
Rancho ES3000 Front shock converted from bayonet style to eyelet style
Cross Enterprises Rear shock bracket w/ relocated rear shock to axle tube
Coil spring specialist custom front coil springs
Custom Front sway-bar disconnects
Custom National Rear Leaf Springs
Rusty's off-road heavy duty rear leaf-spring shackles
Custom High clearance steering (Teraflex high clearance knuckle, " thick links with extreme duty heim joints and heavy duty steering shock absorber) -- NO BUMP STEER
Borgsen Steering shaft
AGR Superbox 2 steering gear box
AGR high-flow Power steering pump (req'd for hydro-boost braking system)
" hitch steel rock sliders with 3/16" extended body protection / nerf-bars
3/16" custom rear bumper with integrated air tank, swing-out full size tire carrier and set of Hella 55watt flood lamps
" plate reinforced oil pan
Transfer case skid plate
Drivetrain:
Dana 44 Rear axle w/ Superior Axles, 4.88 DANA Ring and Pinion w/ OX locker
Dana 30 High pinion w/ Superior Axles and 297x U-joints, 4.88 Dana Ring and Pinion w/ OX locker
Tom Woods Front and Rear custom HD drive-shafts
242 Transfer case w/ MIT slip-yoke eliminator
Jasper AW4 Transmission -- 6k miles with Trans cooler (Amsoil ATF used)
Automatic Transmission controller chip (converts power / comfort switch to stay in 1st or 2nd gear depending on position)
Autometer Transmission temp gauge on A-plr pod
Brakes:
Custom stainless steel braided front / rear brake lines
Custom rear disk brakes (Mustang Cobra rotors)
Hydratech custom hydro-boost master cylinder (2600psi line pressure)
Front / Rear brake bias proportioning valve
Autospecialty cross drilled front rotors w/ EBC "Green Stuff" brake pads
Performance:
Borla Stainless Steel Header
Borla Stainless Steel Cat-Back exhaust
Randon Stainless Steel High-Flow catalytic converter
Adjustable map sensor w/ Autometer Air to Fuel gauge on A-plr pod
K&N Air filter charger
MORE (Mountain Off-Road Enterprises) Bomb-proof engine mounts
Triple core Wolverine Radiator w/ 180 degree thermostat
Flow-Kool high volume water pump
HD fan clutch (replaced at 130k)
Mopar High-flow Oil pump
Mopar High performance timing chain / gear (replaced at 130k)
Mopar rod and main bearings (replaced at 130k)
Electrical:
Optima Red Top Battery
180amp PowerMaster alternator
Alpine Stereo system -- all fused and run with monster cable (4AWG and 8AWG)
o Deck -- 7618 w/ remote control
o 6 Disk CD changer -- 5960
o Clarion Equalizer -- 920EQ
o Alpine MRV-F400 Amp (500watt)
o MB Quartz 130.03kx (x2)
o JL Audio xxxxx
o Rockford Fosgate Punch 200ix DSM Amp (600watt)
o 10" JL Audio subwoofer
Cobra CB radio w/ K40 antenna (tuned and tucked in close to the body to prevent getting snagged in woods)
GMKLR50 is offline   Reply With Quote
Old April 10th, 2012, 11:29 AM   #2
coolkak12
coolkak12's Avatar
WOW! very nice build. where do you work? can i get an application?
coolkak12 is offline   Reply With Quote
Old April 10th, 2012, 11:34 AM   #3
GMKLR50
Broke wheeler
GMKLR50's Avatar
like I said its not mine, its a neighbors, I have lived in my house for a little over a year and have never talked to him. I just came across it searching
Old April 10th, 2012, 02:30 PM   #4
mschaffer66
mschaffer66's Avatar
Little did you know you lived next to a crack house...
Old April 11th, 2012, 01:47 PM   #5
GMKLR50
Broke wheeler
GMKLR50's Avatar
friendly neighbor bump
Old April 19th, 2012, 06:39 AM   #6
GMKLR50
Broke wheeler
GMKLR50's Avatar
week bump
Old August 1st, 2012, 09:52 AM   #7
GMKLR50
Broke wheeler
GMKLR50's Avatar
this is still for sale, and I believe he is down to $6500
Page generated in 0.33998 seconds with 43 queries
