Info on '99 tracker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 9th, 2012, 08:42 PM   #1
rentalrider
rentalrider's Avatar
Default Info on '99 tracker
Well, my son is gonna be getting his first vehicle. It's a '99 chevy tracker with the 1.6l 4cyl, stick shift. It's the 2dr convertible. Bone stock. So... I'm clueless on these things except the gas mileage. It's gonna be a DD with occasional trails, etc but he's at the age when looks count too so looking to make it appear a bit tougher and perform a little better off road. I've read that 225/75/15 tires will fit without rubbing. Anyone have experience with mild lift, 31's? anything similar? Open to any/all info and suggestions. Not used to picking up vehicles I know so little about. Thanks in advance.
Old April 10th, 2012, 07:35 AM   #2
rentalrider
Really? No-one knows anything about these things?
Old April 10th, 2012, 09:16 AM   #3
bdd1469
bdd
bdd1469's Avatar
If it has the 2.0 motor,make sure the timing belt has been changed.They have been known to bend valves when they brake.I havnt heard anything bad about them,other then that.
We had 30/9.50s on my freinds 99 4 door,they rubbed a little too much with no lift.
Check out rocky road and trail tough for parts and ideas.
Old April 10th, 2012, 09:37 AM   #4
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
There is a suzuki forum here, so look around there as well. I have considered one for a winter beater/light wheeler as well. I think you can do a 29-30 tire with a home-brew er.. cheap lift.
RIP FULLSIZE4LIFE
Old April 10th, 2012, 09:39 AM   #5
buddyayres
DAAM Racing
buddyayres's Avatar
Send a message via AIM to buddyayres Send a message via MSN to buddyayres Send a message via Yahoo to buddyayres
make sure to check the front suspension crossmember. the like to rust out where they connect to the control arm attachment brackets. their known for rotting out. if it is then its not worth buying. I've know a few people who's had the problem. it cause so many problems. tire wobble, steering looseness, veihical pull to one side, front end noises ( clunk, bang, rattle, act.), vehicle shaking, or steering wheel rotations when shifting from reverse to drive or drive to revers.
buddyayres is offline   Reply With Quote
Old April 10th, 2012, 09:55 AM   #6
rentalrider
Ok, thx. Will def check that out and if rusting bad I'll brace it and weld her up. It's the 1.6btw.
Sent from my DROIDX using Tapatalk
Old April 10th, 2012, 10:10 AM   #7
tonkatruckon44s
tonkatruckon44s's Avatar
old man emu is a company that makes lift kits for the trackers and samurais bought one for my buddies
tonkatruckon44s is offline   Reply With Quote
Old April 10th, 2012, 10:18 AM   #8
Complete Off Road
Complete Off Road's Avatar
check out lowrangeoffroad.com and trail-gear.com
Complete Off Road is offline   Reply With Quote
Old April 10th, 2012, 11:06 AM   #9
rentalrider
Thx guys. Btw mods I didn't know there was a suzuki section... Could you move this there if I put in wrong place? sorry about that.
Old April 10th, 2012, 04:33 PM   #10
bdd1469
bdd
bdd1469's Avatar
Yes and no. We have bought several 99 up trackers because the crossmember rotted out.
You buy them cheap,then go to chevy to have the recall done.This cross member is bolted in,and no big deal to change.
Old April 11th, 2012, 05:57 PM   #11
buddyayres
DAAM Racing
buddyayres's Avatar
o alright. i had to do some research on one for a friend of mine. I've never owned one so i didn't know. i just knew where to look and how to test it. but i will remember what you said.
Page generated in 0.27103 seconds with 56 queries
