Truck need starting fluid after sitting a week - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 11th, 2012, 06:47 AM   #21
Monster80
Monster80's Avatar
Fuel filter plugged? leak in gas line? If them are good the is there a leak in the gas line? The carb could also not be holding the pressure when shut off and allowing the fuel to drain back. There's a filter you can buy to fix that for awhile until you rebuild carb. Just thongs to look at
Monster80 is offline   Reply With Quote
Old May 11th, 2012, 05:31 PM   #22
booblinker
Sore and Tired 24/7
booblinker's Avatar
Guy at work that knows carbs well says by fuel bowls are leaking off, guess I'll be rebuilding my carb next weekend.
Old May 11th, 2012, 06:03 PM   #23
Elvis13
You should be able to pull the small screw on the side of the bowl to check and see if the fuel is staying in there? If the bowl is full and the level is set properly it should be up to the bottow of the opening.
Also, i'm guessing you could fill them up from there as well. That may help identify the issue as well.
Old May 12th, 2012, 05:06 PM   #24
booblinker
Sore and Tired 24/7
booblinker's Avatar
I'll start with this
Page generated in 0.13782 seconds with 35 queries
