Truck need starting fluid after sitting a week - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 8th, 2012, 09:48 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default Truck need starting fluid after sitting a week
It used to start after sitting weeks in like 2 cranks. Now after sitting for less than a week it needs a whiff of starting fluid, just a whiff and it will start and run fine. I am thinking my fuel pump is bad, and causing the fuel to go back to the fuel pump. Its a 69 F250 with a FE 360.
booblinker is online now   Reply With Quote
Old April 8th, 2012, 10:01 PM   #2
MilwaukeeF350
Dan
Convert to electric fuel pump is best investment for these.
Manual fuel pump are pita require alot crank to get fuel up to carb.
Old April 8th, 2012, 10:08 PM   #3
smasheromalley
smasheromalley's Avatar
Is the choke closing on the cold start? Are you pumping the pedal a couple times before cranking?
The fuel pump shouldn't make a difference. There should still be fuel in the carb bowl.
Old April 8th, 2012, 10:13 PM   #4
booblinker
Sore and Tired 24/7
booblinker's Avatar
Manual choke, im guessing the small amount of fuel in bowl would evaporate within a week.
Old April 8th, 2012, 10:14 PM   #5
booblinker
Sore and Tired 24/7
booblinker's Avatar
Yea I thought about it, not 100% decided on whether to stay stock, or do an electric, price is about the same either way.
Old April 9th, 2012, 01:04 AM   #6
smasheromalley
How is it a best investment? Is there something inherently wrong with the design of the fuel pump on the 360 fe?
mechanical fuel pumps work fine. Unless the lobe or tab that actuates the pump is damaged there is no reason to go to an electric pump. Actually there are probably more reasons not to.
Old April 9th, 2012, 08:13 AM   #7
MilwaukeeF350
Dan
At my work we had 4 trucks with 429/460 that had 4 barrel carb. No matter how you try it keep gas stay in carb. Amount of fuel in bowl would evaporate within a week.
How much it cost you to replace starter every year because you keep CRANK CRANK for manual fuel pump to prime gas.
These sudden start issue 4 years ago and it wasn't manual fuel pump issue. It gas that is evaporate faster.
Old April 9th, 2012, 08:36 AM   #8
Elvis13
It's junk, i'll give ya 1000 bucks for it.
Old April 9th, 2012, 10:53 AM   #9
frdboy
frdboy's Avatar
X2....
Put a new mech. pump on it and be done.
Old April 9th, 2012, 09:49 PM   #10
masterbeatty
masterbeatty's Avatar
i had an electric pump on my 77 with a 400 and went and bought the stock mech pump. more reliable, less draw on an already soso charging system. just not enough benifit.
Old May 10th, 2012, 08:16 PM   #11
booblinker
Sore and Tired 24/7
booblinker's Avatar
Well it looks like I am going to convert to an electric fuel pump, still having the same issue with the new fuel pump.
Old May 10th, 2012, 08:35 PM   #12
Elvis13
What is convincing you it's the fuel pump?
Old May 10th, 2012, 08:41 PM   #13
booblinker
Sore and Tired 24/7
booblinker's Avatar
Im thinking it starts on starting fluid, and gets the fuel pump moving fast enough to get enough gas to the carb, so an electric ran for 3 seconds would get enough gas to the carb to get it running.
Old May 10th, 2012, 08:46 PM   #14
MilwaukeeF350
Dan
It pop me after see several old diesel trucks.
They had manual pump hook but they add electricc inline fuel pump for these reason.
Turn on fuel pump until it start run then turn off let manual fuel pump do work after that.
Old May 10th, 2012, 08:52 PM   #15
JeepInABox
In too deep
JeepInABox's Avatar
how about a electric pump with a 3 second timed relay to prime the pump at ignition on then pass thru for the mechanical
Old May 10th, 2012, 09:25 PM   #16
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
have you checked the fuel pump push rod travel? i have seen on older engines the fuel pump cam gets worn so bad the pushrod barely moves. it certainly won't be enough to pump any fuel at cranking speed.
Old May 10th, 2012, 09:33 PM   #17
booblinker
Sore and Tired 24/7
booblinker's Avatar
No push rod on a Ford FE motor
Old May 10th, 2012, 09:36 PM   #18
cruzer72
cruzer72's Avatar
Accelerator pump on carb could be the issue.
2015 Wrangler Unlimited
1985 S-Blazer 4 linked, 427ci
1963 Nova SS 350hp I6
1972 Monte Carlo
1993 Tracker 4:1 Case, 33" KM2
cruzer72 is offline   Reply With Quote
Old May 10th, 2012, 10:55 PM   #19
Elvis13
Why don't you clean the carb first and then go from there?
Old May 11th, 2012, 12:04 AM   #20
smasheromalley
Ive had carb'd vehicles sit for weeks, probably months and not had this kind of problem.
Have you done a flow/pressure test on the new mech pump? Mebbe a clear fuel filter up near the carb to give an idea what's going on?
If an electric pump fixes it then its just masking another problem, but sometimes if shit works it works. Good luck with it
Page generated in 0.34667 seconds with 83 queries
