99-01 XJ Cherokee 4.0L - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2012, 12:14 PM   #1
Gunsworth
Gunsworth's Avatar
Default 99-01 XJ Cherokee 4.0L
doesnt need accessories, all are good on the one i need to replace in our 00 xj
Old April 9th, 2012, 07:26 AM   #2
Gunsworth
Gunsworth's Avatar
Bump, and would rather have 00-01, will consider, low mileage 97-99
Old April 9th, 2012, 08:15 AM   #3
1 ton tj on 40's
1 ton tj on 40's's Avatar
try zemkos they had some 97-99 when i called them looking for a 2000 or new. good luck.
Old April 9th, 2012, 08:20 AM   #4
94cherokeemike
IT'S A XJ THING
94cherokeemike's Avatar
We should have one at my work
Bridge lake auto in clarkston 248 625 5050
94cherokeemike is offline   Reply With Quote
Old April 9th, 2012, 08:40 AM   #5
1 ton tj on 40's
how about a 2000/05 diret ignition?
Old April 9th, 2012, 12:13 PM   #6
Gunsworth
Gunsworth's Avatar
they have a 2000 from an xj, 1100$... from what i have been reading though, TJ and XJ motors are quite a bit different. TJ/WJ interchange no problem, the accessroies and mounting areas are completely different on XJs.
Seems like everyone wants 1k plus for these motors. Really regretting buying this jeep last year
Old April 14th, 2012, 11:42 AM   #7
Gunsworth
Gunsworth's Avatar
Still lookin
Sent from my SPH-D710 using Tapatalk 2
Old April 15th, 2012, 10:39 AM   #8
kargod
Charcoal Mellowed
kargod's Avatar
I tried for a couple months to find one, then just redid my 2000 cylinder head and bought a 1999 engine for $250 from a ghetto yard. It has been around for three years and runs great.
Please pm me if you go to sell it whole without the engine replaced.
kargod is offline   Reply With Quote
Old April 15th, 2012, 07:18 PM   #9
Gunsworth
Gunsworth's Avatar
well i am guessing the head is cracked and the leaking coolant killed the motor, could be wrong. so did you transfer over the coilpack stuff then?
I am not in a huge hurry to fix it so I am gonna keep looking, the jeep is too clean and solid aside from the motor to walk away from, also only had it a year
cant believe how many people want 1k plust for these motors with over 100K, if it comes down to it ill just get a reman. worst part is that a friend sold one with 100k from a 2000 for 400$ a week before this blew
Old April 16th, 2012, 03:08 PM   #10
kargod
Charcoal Mellowed
kargod's Avatar
Yeah, transferred my head and the cam position sensor... mine had an oiling issue for either cylinder 5 or 6 that wiped out the rod. It was knocking pretty good but still ran. I guess that is as common as the head cracking. Pull your head off and have someone reputable check it out. If it comes back good then you are in business.
Old April 22nd, 2012, 12:50 PM   #11
Gunsworth
Gunsworth's Avatar
Found one!
Page generated in 0.28754 seconds with 56 queries
