Welding cast iron exhaust manifold - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2012, 08:02 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default Welding cast iron exhaust manifold
I have a mig and Arc welder. Can you heat it up to around 600*F and mig it with regular flux core, than throw it in the oven and slowly cool it?
or should I just use the arc welder? What rod ? I have very little experience with the arc welder... what settings?
I'd just rather use the mig unless it will not hold at all
Old April 4th, 2012, 09:27 PM   #2
treky67
millwright/jeepwright
treky67's Avatar
Mig will not work at all, will most likely crack. No matter what method you use for welding the cast it will need to be both pre and post heated. Your gonna be best off with you stick welder and a high nickle content rod. Any welding supply shop should be able to point you in the right direction when it comes to a rod specifically for cast iron.
treky67 is offline   Reply With Quote
Old April 6th, 2012, 07:48 AM   #3
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
Do some research on aluminum bronze tig rid.
Sent from my MB525 using Tapatalk
Mulely is offline   Reply With Quote
Old April 6th, 2012, 07:53 AM   #4
cj65
cj65's Avatar
Certanium alloy sells a rod just for cast iron welding no pre or post heating needed.
Old April 6th, 2012, 07:54 AM   #5
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Find a used one from the junk yard. It isn't worth the hassle for what you can buy one for. If you decide to repair make sure to drill the ends of the cracks or it will just continue to crack.
Old April 6th, 2012, 02:39 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I have been reasearching it like crazy.... but its one of those things where some say , "i've been welding for 20 years and I have never had an issue with using regualr mig welding."
Some will say it just cannot be done with either, some say you have to use this or that rod, have to heat it to this temp and anything more or less it will not work.
Its for a 67 Olds so I can't just go to the junkyard, ebay they want $400. The ear is completely broke off to, its not just a simple crack.
I might just mig it, if that does not work i'll go out and spend money for rod. At least I can try what I have here.
Old April 6th, 2012, 03:19 PM   #7
DIGnLIFE
DIGnLIFE's Avatar
I have a lot of experience with cast. You need nickel rod and arc for sure. V grove the crack/ joint with a grinder. Pre heat with a torch. Weld it. Nickel rod burns alot different than most arc rods. I would suggest you try a couple times on a scrap manifold to get the feel and heat right.
DIGnLIFE is offline   Reply With Quote
Old April 6th, 2012, 07:32 PM   #8
trailtwister
Don't Insult My Stupidity
trailtwister's Avatar
Listen to DIGnLIFE he knows what he is talking about. If you have access to a welding supplier see if you can get a TEMP STICK for cast iron. That way you can pre heat to the right temp before you start. If you don't have access to someones asbestos blanket to cover it up to slow down cooling process, you might try using a oven.
Otherwise you are wasting your time and will have junk when you are done.
trailtwister is offline   Reply With Quote
Old April 7th, 2012, 09:58 AM   #9
I suck cocks. Lots of them.
locally famous
you should find a donor head to bolt to also, hate to get it done and find that it wont fit
Old April 9th, 2012, 12:03 AM   #10
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
thanks for the tips guys. have not had a chance to get this done, soon though. I'll go talk to the welder stores in town here and see what they have. I've heard of that pen before.
For a donor head.... no dice. I will just make a template with flat steel and bolt it to that and hope it works. If it warps I can have my neighbor machine it flat.
Old April 9th, 2012, 08:57 PM   #11
shawn
Resident HVAC/R Jambi
shawn's Avatar
x2
Lots of preheat, and cool slow. I've put a welding blanket of cast after I've welded it to help keep it hot. And I've actually stuck some pieces in the rod oven to keep them hot and cool it slower.
Old April 9th, 2012, 09:08 PM   #12
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Flux core
H.o.r.e
Old April 9th, 2012, 09:23 PM   #13
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I'm amazed. all the know how on this site and nobody sees the tools they have around them?
ok you need to weld the manifold while hot. that helps deal out the prospects of cracking after the weld is laid. use a freaking Barbecue! put some foil down if you want but its a perfect annealing chamber. set up your work and then crank up the gas grill and bake to about 400*f. once hot open the lid weld the thing and then close to bake in the heat. let cool after you have finished both sides. piece of cake!
oh yeah doing like this you can get away with a mig welder flux core or not.
if you have a stick machine use the nickle drag rod. that works great.
Yetti
Old April 9th, 2012, 09:29 PM   #14
schanxj
schanxj's Avatar
That's ingenious!
schanxj is offline   Reply With Quote
Old April 9th, 2012, 09:38 PM   #15
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
for a 330? if so I might have one from a 64
Old April 11th, 2012, 07:05 PM   #16
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
yes sir. a 330 jetfire
Old April 13th, 2012, 08:02 PM   #17
Christmas Cookie
nevermind...my dad gave them away
Old April 22nd, 2012, 09:24 AM   #18
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
picked up some nickel rod the other day and welded it up. Looks good and seems strong. Installed the manifolds and its holding... time will tell I guess
Page generated in 0.35145 seconds with 77 queries
