Mudd Warz - May 5th at Thunderbird Raceway - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old April 3rd, 2012, 07:19 PM   #1
dirty1ton
dirty1ton's Avatar
Default Mudd Warz - May 5th at Thunderbird Raceway
4 divisions of trucks: pro truck or super modified, 200 to win. modified truck, 200 to win ,stock 4x4 trucks 200 to win. 2 wd trucks ( factory) 100 to win. Gates open at noon, muddin at 4 pm. Awards will be givin to 2nd and 3rd in each division. Driver pit pass 25.00 General pit pass 20.00, General grand stand 10.00, Kids 7 to 12 5.00 , kids 6 and under free, for early set up call Carl at 231-821-7006. Come out and enjoy the muddin fun at Mudd War'z.
dirty1ton is offline   Reply With Quote
Old April 4th, 2012, 05:01 PM   #2
rehab532
rehab532's Avatar
bump
rehab532 is offline   Reply With Quote
Old April 9th, 2012, 11:31 PM   #3
mudinwhatever
mudinwhatever's Avatar
hell yea is it just those small washouts in the center of the track or what?
mudinwhatever is offline   Reply With Quote
Old April 10th, 2012, 07:36 AM   #4
dirty1ton
dirty1ton's Avatar
It's gonna look like a whole new pit when you see it.
Old April 14th, 2012, 10:15 PM   #5
hlfbrd71
hlfbrd71's Avatar
what are the classes in each division? How do you have them split up?
hlfbrd71 is offline   Reply With Quote
Old April 15th, 2012, 07:33 PM   #6
chevota02
Hammer Time
chevota02's Avatar
What are the rules for the classes??
chevota02 is offline   Reply With Quote
Old April 16th, 2012, 09:14 AM   #7
bigyj
bigyj's Avatar
More on the rules also. I have a bone stock 4banger but with 42" tires what class?
bigyj is offline   Reply With Quote
Old April 21st, 2012, 07:16 AM   #8
dirty1ton
dirty1ton's Avatar
I copied this so people could get info.
we are using west mich mud assosiations rules, our top division is protruck or supermodified, anything goes in that division, read class 7 for saftey rules, next class is modified truck -witch follows class 6 , stock 4x4 trucks - use class 1 rules, stock 2 wheel drive , car or truck, will allow 33's , if you need more info call carl at 231-821-7006, thank you
Old April 21st, 2012, 07:25 AM   #9
dirty1ton
dirty1ton's Avatar
Here are the rules for the classes:
General Truck Rules
Solid tow out point (Each and every driver MUST pull a cable)
Helmets and seat belts required by all vehicle occupants
Fire Extinguisher on board
GOOD SPORTSMANSHIP is required or you will be asked to leave!
$20 one time entry fee per driver, per truck, per class
Classes and Rules
Class 1 36.5" DOT (non cut) tires and under
4x4 vehicles only-production type frames and suspension
Any motor drive train combination
Front of motor can not be behind center line of front axle
Body swaps allowed with motor in stock location of frame, axles within 6" of center of wheel well
Flat beds and gutting allowed, must maintain stock appearing bodies (not homemade)
Must have doors, hood, and firewall. Replacement fiberglass body or parts ok
Single carb, gasoline only, no nitrous
No aluminum heads or aluminum blocks permitted
Vehicles with factory support of cab cut, or glass removed, open or soft tops MUST have roll bar to the frame
Passengers allowed at the discretion of the track owner
Maximum engine size 514 cubic inches
Class 2 44" DOT (non cut) tires and under
Same rules as class 1
CLASSES 1 AND 2 ARE MEANT FOR LOWER BUDGET BEGINNERS, IF YOU SHOW UP WITH HIGH DOLLAR MOTOR TO RUN THOSE CLASSES, YOU WILL BE BUMPED UP TO CLASS 3 AND 4
Class 3 36.5" DOT (non cut) tires and under
​4x4 vehicles only-production type frames and suspension
Any motor and drive train combination
Body swaps allowed
No aluminum blocks permitted
Aluminum heads allowed- conventional type only
Engine set back should be no more than 12" from centerline of axle to #1 spark plug
No aluminum hubs
No nitrogen shocks
No fiberglass or carbon fiber springs allowed
Wide five wheels are ok if they are used with an adapter, no wide five hubs
Class 4 44" DOT (non cut) tires and under
Same rules as class 3
Class 5​ 39.5" DOT tires and under
Cut DOT tires allowed
2"x3" square tube frames ok
4 link and other adjustable suspensions allowed
Engine must be in front of driver
Fiberglass bodies ok, no full fiberglass racing bodies
Max deck height Ford-10.320 GM-10.200 Chrysler-10.72
Alcohol through carb, no injection
Any enclosed transfer cases
Gutting allowed
Must be naturally aspirated
​Small blocks can run a 300 shot of nitrous, iron headed big blocks can run a 250 shot of nitrous
​FIRE SUITS REQUIRED!!!
Minimum four point harness
Roll cage requirements: 6 point minimum, with 4 points to the frame. .090 min thickness 1 5/8 min. on main support
Master kill switch within driver's reach with an exterior kill switch on right rear of vehicle
Maximum wheel base of 150"
Wide five wheels ok
NO PASSENGERS!!!
Class 6 54" DOT tires and under
Same rules as class 5
Class 7
ANYTHING GOES!!
Paddles and tractor tires ok
FIRE SUIT REQUIRED
NO PASSENGERS
Minimum 4 point harness
Roll cage requirements: 6 point minimum, with 4 points to the frame. .090 min thickness 1 5/8 min. on main support​
This is our first year putting this on,so any suggestions would be helpful.
Old April 25th, 2012, 12:49 PM   #10
dirty1ton
dirty1ton's Avatar
please call 231-955-4522 for any info, please do not call 821-7006. thank you, carl califf
Old April 25th, 2012, 01:00 PM   #11
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
Not to smart to make it the same day as trucks gone wild wouldnt ya say
AJ Hall is offline   Reply With Quote
Old April 25th, 2012, 02:42 PM   #12
dirty addiction
dirty addiction's Avatar
is this going to be a bog pit or more of a drag pit?? what is being used for pull out??
dirty addiction is offline   Reply With Quote
Old May 1st, 2012, 05:33 PM   #13
racin jason
West Michigan Mud Runs is very flatterd that the promoter has decided to follow most of our rules. Just a FYI this is not a west michigan mud runs event. I am planning on going to watch, hope to see some of you guys there.
racin jason is offline   Reply With Quote
Old May 1st, 2012, 06:26 PM   #14
dmcjeep
dmcjeep's Avatar
Why just to spectate? Truck not running. I was going to go but I guess they do not want stock trucks there either.
dmcjeep is offline   Reply With Quote
Old May 1st, 2012, 07:57 PM   #15
racin jason
Still have things to finish on the truck, will be ready for may 19. You should call the guy because I think there is some stock type classes. I know there is a 2wd class that is not listed.
Old May 1st, 2012, 08:23 PM   #16
IDIeselman
IDIeselman's Avatar
There is a stock class....$200 to win.
Old May 1st, 2012, 08:57 PM   #17
dmcjeep
dmcjeep's Avatar
stock 4x4=class 1 rules. From what I remember about those rules it is not exactly stock. I did talk to the guy running things and I suspect there might be some issues with this.
Old May 3rd, 2012, 08:10 AM   #18
dirty addiction
denny theres always issues woukldn't be a mudrun with out them!!!!
Old May 3rd, 2012, 08:11 AM   #19
dirty addiction
from what ive heard possable 3to4 ft deep with 6 to 8 '' of water on top 160 ft. pit and a play area after comp run.
Old May 5th, 2012, 08:54 AM   #20
dmcjeep
dmcjeep's Avatar
Todys the day. I am headed out for a bike ride and will see how that goes. If it ends soon enough I think I just might try and make it over to the mud run. I think the jeep is ready.
Page generated in 0.57257 seconds with 83 queries
