How messed up is this? Superduty axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 1st, 2012, 10:02 PM   #1
smasheromalley
smasheromalley's Avatar
Default How messed up is this? Superduty axle
So A couple weeks ago i had balljoints and a rod end done on my truck (2000 f350). Today I crawled under to look for a coolant drip and I found this
It's hard to see but it looks like a piece of the seal around the axle stub has come off? Is this a regular failure or did they screw something up?
I have some other complaints about the place that did the work, just wondering if I can add this to the list.
Old April 1st, 2012, 10:07 PM   #2
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Dude that's pretty messed up
Old April 1st, 2012, 10:19 PM   #3
Bones
Bones's Avatar
fairly normal failure, that seal really is only in place for vac hubs.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 1st, 2012, 10:21 PM   #4
smasheromalley
Aight then. Auto hubs havent worked for a while. Thanks
Old April 3rd, 2012, 07:07 AM   #5
kickstand
circling the drain
kickstand's Avatar
I have one of those seals floating around my garage for the exact same reason, came with my truck....you can have it.
Old April 3rd, 2012, 04:58 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
find cheap manual hubs on escam and be done with it.
take up kickstand on his free seal offer. those are not cheap.
Old April 3rd, 2012, 05:16 PM   #7
smasheromalley
I was mainly worried that the place who did the work fukcered up the seal and didn't replace it, or that it was a seal that should have been replaced as part of the work they did.
Old April 4th, 2012, 09:44 PM   #8
TIRES_ARNT_CHEAP
Them live systems suck! Buy a full lock out kit.
TIRES_ARNT_CHEAP is offline   Reply With Quote
Old April 16th, 2012, 08:59 AM   #9
natureboynate47
natureboynate47's Avatar
that seal should have been replaced if that was the side they put ball joints on. it should still be replaced even if you dont have or use vacuum hubs. that seal also helps keep the axle shaft aligned properly. could casue excessive wear on the needle bearing in the
hub that the shaft rides on. btw you also need to use the right tool for pounding that seal on the axle shaft.
natureboynate47 is offline   Reply With Quote
Old April 16th, 2012, 09:06 AM   #10
booblinker
Sore and Tired 24/7
booblinker's Avatar
I've also seen people needed knew outer stub shafts because of this seal being blown out.
Old April 16th, 2012, 11:23 AM   #11
I suck cocks. Lots of them.
locally famous
so is the axle still leaking coolant?
Old April 16th, 2012, 02:07 PM   #12
natureboynate47
i had to look twice, that's funny
Old April 29th, 2012, 11:04 AM   #13
smasheromalley
They put ball joints on both side. And thanks, that was what i suspected.
Page generated in 0.23468 seconds with 62 queries
