Adjusting Backlash on manual steering gearbox - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 1st, 2012, 09:21 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default Adjusting Backlash on manual steering gearbox
I have a 69 f250 with a manual gearbox that is sloppy, I have read that i can adjust the backlash, but I need to find a manual to explain how to do it, since its easy to mess it up. Does anyone have the procedure on how to do it?
Old April 1st, 2012, 09:51 PM   #2
Coyote Red
Coyote Red's Avatar
If it is a NP-435 take a look at this link. It shows GM but any manual from the big three will work. "http://www.scribd.com/doc/57346896/NP435-Repair-Manual" remove the quotation marks. This is the same one but a larger image size and a PDF file. http://home.comcast.net/~vx/NP435_Repair_Manual.pdf
Coyote Red is offline   Reply With Quote
Old April 1st, 2012, 09:57 PM   #3
buttercr125
I work out
buttercr125's Avatar
I do believe he is referring to a steering gear box. If so there should be an adjuster and lock nut located on the top of the box.
Old April 1st, 2012, 10:54 PM   #4
Coyote Red
Coyote Red's Avatar
I see that now. I saw manual gear box and thought of a transmission. Well I guess I found a manual to when I tear down my transmission.
Old April 1st, 2012, 11:03 PM   #5
booblinker
Sore and Tired 24/7
booblinker's Avatar
Fixed the thread for less confusion.
Page generated in 0.19540 seconds with 38 queries
