98 cr250r - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 31st, 2012, 02:51 PM   #1
OFFROAD MAFIA
OFFROAD MAFIA's Avatar
Default 98 cr250r
The bike is a 1998 cr250 i am the third owner and have tital in had the bike has a fresh top end with 2.8 hours on it (broke in properly i used the heat cycleing method if familiar with that) when doing the top end i also went and put in new crank bearings and counter shaft bearings all new seals and gaskets and all new studs and bolts on the motor new boysen reeds full hinson billet clutch inner and outer basket with pressure plate .the clutch pack and springs are new but they are oem .it has new renthal sprokets front and rear with a new d.i.d o-ring chain new wheel bearing new brake pads and i changed and bled the brake fluid last fall new clutch cable the oil has been changed after every or every other weekend of riding the air filter was cleaned after every rideing trip i mainly just rode this bike on the trails in st helen im pretty particular about my bikes so it was well taken care of i have two twin-air air filters and a complet 18 inch rear wheel with a sand paddle mounted on it that comes with the bike and after the rebuild i put a works connection hour meter/tach on so i knew exactly how many hours are on the new motor and every thing else for maintenance purposes i do have a folder full of receipts to document that the top end is new im only selling because i want a down payment on a new street bike and im asking 1800 OBO pm if intrested im located in dearborn heights
mods
fmf fatty pipe
fmf turbine core silencer
fx gripper seat
ims pro pegs
works connection radiator guards
full billet hinson clutch
ID:	90995   Click image for larger version
ID:	90996   Click image for larger version
ID:	90997   Click image for larger version
OFFROAD MAFIA is offline   Reply With Quote
Old April 14th, 2012, 02:35 AM   #2
Waychoff05
Waychoff05's Avatar
Nice bike!! Still got?
Waychoff05 is offline   Reply With Quote
Page generated in 0.20162 seconds with 30 queries
