95 s10 4x4 ext cab - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 30th, 2012, 02:23 PM   #1
tjohns
Default 95 s10 4x4 ext cab
95 s10 202xxx, ext cab 4x4. transmission professionally rebuilt at 195xx, it is rusty
31/10.5/15 toyo open country, needs front two tires replaced
new (replaced within past 8 months)
battery
distributor
ing. coil
cap
rotor
plugs + wires
starter
fuel rail & injectors at 198,xxx (fuel lines under plenum too)
fuel pump + sending unit
water pump
outer tie rods
pitman arm
idler arm
oil cooler line to radiator
master cylinder
break booster
flow master exhaust
sway bar links
needs
pass. side door fixed (sagging)
neutral safety switch, this indicates which gear you are in on the dash and works with the tccm for 4x4.
back breaks (have shoes+hardware kit)
inner tie rods
oil cooler line, i have it just needs to be installed, it is not leaking more than a drip or two.
front tires,
motor has tons of power and trans shifts smooth, the truck just needs some tlc
1700 cash
poss trade for motorcycle, dodge trans 46RH and cash,
or 285/75/16 bfgs, toyos, aggressive tread+cash
tool box (locks, and i have the key) included if you pay asking price
http://detroit.craigslist.org/okl/cto/2907595259.html
tjohns is offline   Reply With Quote
Tags
cheap, gas saver, ranger, s10
Page generated in 0.14910 seconds with 26 queries
