Check Engine Light - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 9th, 2006, 06:00 PM   #1
Eddy Bower
HillBilly Deluxe
Eddy Bower's Avatar
Send a message via AIM to Eddy Bower
Default Check Engine Light
I have a 96 F-150 5.8l..i had the exhaust done headers and true duals going into dual flow 40 series and dual rear exit. My Check engine light is on and it is smokin like a diesel when i floor it..and sometimes when i stop. it doesnt have cats on it. has 3 o2 sensors on it..2 on either header and one about 5 feet down the exhaust..could it be the sensors? is the anyway to bypass that if it is the sensors? Thanks for the help
Eddy Bower is offline   Reply With Quote
Old October 9th, 2006, 06:42 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
You're running too rich. MIL is probably on because your 02 sensors are detecting that. Run your truck over to autozone and have them scan it and get the code. It's free.
Old October 9th, 2006, 08:53 PM   #3
chris1044
chris1044's Avatar
First thing I thought of after i saw "I'm not running cats" is it's setting a code for a catylist inefficiency code - assuming the "one that's 5 feet down the exhaust" is a post cat sensor (when he did have the cat on)
But, if it is smoking black it's running rich, and that's probably tripping the code as well
Old November 24th, 2006, 03:38 PM   #4
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
That would be my guess too. Check out some of the Mustang forums, they run "dummy" O2 monitors after the cats to fool the pcm into thinking that all is well.
Troll53 is offline   Reply With Quote
Page generated in 0.20747 seconds with 35 queries
