pintle hitch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 28th, 2012, 08:43 PM   #1
gixxer1397
gixxer1397's Avatar
Default pintle hitch
Ok guys sorry for all the newbie questions about the trailers, but i have been looking into getting a used one obviously the cheaper the better, so with that in mind would you recommend towing your rig or maybe even 2 with a trailer that has a pintle hitch instead of a regular ball style.
gixxer1397 is offline   Reply With Quote
Old March 28th, 2012, 08:49 PM   #2
Freak
Wheelin the HD
Freak's Avatar
No, but I'm picky. I don't like how they "bang" when you stop and go. That said we use them at work.
Old March 28th, 2012, 08:51 PM   #3
in2deep
Hole tester
i dont like them i would convert it to a ball
Old March 29th, 2012, 09:59 AM   #4
nickb304
nickb304's Avatar
they are not to bad if you have enough weight on them, but they are enough to drive you insane other wise. i found a 12k rated 2-5/16 coupler that bolted in place of the pintle loop on the front of our equipment trailer. its 100% less annoying.
nickb304 is offline   Reply With Quote
Old June 25th, 2012, 02:13 PM   #5
4x4 Addict
Newbie to not 4x4
This site might something you wanna check.
http://www.hitchanything.com/
4x4 Addict is offline   Reply With Quote
Old June 25th, 2012, 02:44 PM   #6
deerebowtie
Unchained
deerebowtie's Avatar
5th wheel. large bumper pull trailers suck
Old June 25th, 2012, 03:24 PM   #7
silveradoboy
Sam Brown
silveradoboy's Avatar
My friend has a huge dent in his tailgate after a trailer popped off of the ball while loading a jeep onto a flatbed. Pintle is better in that aspect.
silveradoboy is offline   Reply With Quote
Old June 25th, 2012, 03:30 PM   #8
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I would much rather have a pintle. I have seen lots of ball hitch trailers come off but I have never seen a pintle style come off. The noise has never bothered me, I use them all the time.
Old June 26th, 2012, 12:02 PM   #9
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
pintles do make noise but i have never had one fail.
Old June 26th, 2012, 01:35 PM   #10
14muddn
My experience is any trailer without much weight will be noisy. However, every pintle hitch I have used has matched the ring. I have heard the pintle/ball hitch combos have some slop and bang around. Anything more than a smaller utility trailer my vote would be pintle.
Old July 3rd, 2012, 09:17 AM   #11
Freak
Wheelin the HD
Freak's Avatar
Our 40 ton pintle hitches have a shock absorber in them to prevent the banging and lurching. Its a pretty swift setup.
Old July 3rd, 2012, 09:26 AM   #12
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old July 3rd, 2012, 10:13 AM   #13
bigblockford79
Big Block Ranger
bigblockford79's Avatar
I would think most ball and coupler failures are user error. Forgetting to latch the coupler happens often, and I bet many trailer users have never adjusted the coupler itself. As long as you have quality components and use them properly, you shouldn't have any issues with either style connection.
Old September 26th, 2012, 09:33 PM   #14
4x4 Addict
Newbie to not 4x4
Not much help with pintle hitches but this might be a site you want to dig in:
http://www.wheelsanything.com/
Old September 26th, 2012, 09:42 PM   #15
chadcooper55
I have seen multiple ball hitches come off that were secured correctly. I have all the stuff to build a trailer and I am putting a pintle on it.
Old October 15th, 2012, 02:38 AM   #16
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
Most Pintle hitches have a higher strenth rating than ball hitches. Make sure whatever you do, you keep your strength rating the same or higher.
fukkinrizzo is offline   Reply With Quote
Page generated in 0.30877 seconds with 71 queries
