Welded or clamped? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 16th, 2005, 06:35 AM   #1
chuckhubbert
chuckhubbert's Avatar
Default Welded or clamped?
I have my new catalytic converter in hand the the Dynomax cat back is supposed to be delivered today. I'm pretty sure I can get it installed myself with clamps, but I'm wondering if having it welded would be a better option?
How much might it cost for installation and welding? Any recommendations for a good shop in North Oakland county?
chuckhubbert is offline   Reply With Quote
Old December 16th, 2005, 10:21 AM   #2
smasheromalley
smasheromalley's Avatar
I have never had good luck with all clamp exhaust. Theres always seems to be some stupid leaks.
Old December 16th, 2005, 10:28 AM   #3
Bones
Bones's Avatar
I always try to us the clamps when possible, that way if you ever have to remove the exhaust to do transmission/tcase/etc work, you don't have to cut your exhaust, or remove it all the way from the manifolds.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 16th, 2005, 10:44 AM   #4
smasheromalley
If I had a choice Id go for bolt together flanges. wleded on to the pipe of course...
Old December 16th, 2005, 10:59 AM   #5
cracker$
cheese
cracker$'s Avatar
Default Clamp then weld
I've installed two catback systems and never had a problem with just using clamps. Having said that... I would recommend you clamp the system on and then in the future if any leaks/vibrations show up, have it welded.
cracker$ is offline   Reply With Quote
Old December 16th, 2005, 11:05 AM   #6
Lothos
KD8GKB
Lothos's Avatar
I would weld the fucker. Clamps provide a slight enough means of restriction to provide a spot for buildup to occur and possibly reduce airflow.
Old December 16th, 2005, 12:15 PM   #7
I'd go weld-on flanges, as mentioned.
Clamps do seem to leak for me, since they really crush from 2 sides, not all 4. You keep tightening them, they crush the pipes enough that you can't get them apart, anyway.
I'd either weld or flange it, myself, although, I've done the clamp thing many times, it'd work.
My current exhaust has a 2.5" pipe clamped to the heater(PO cut off the flange...idiot...), reduced to a 2.25" pipe, pipe is welded, then clamps to my muffler. Mufflers I prefer to clamp, since I often swap them out. Cats, well, if I ran a cat, I'd probably just weld it..
Old January 13th, 2006, 06:31 PM   #8
noodles
give 'er sh*t ay?
noodles's Avatar
i would just clamp it, because as mentioned, if needed to remove it it iseasier, and cheaper.i havent had a problem with the clamps leaking , and if so there is some exhaust pipe goop that will seal pretty much anything.
Old January 13th, 2006, 06:44 PM   #9
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
now see if it was me I would do both, unless I did have clamps. the clamp takes flex better then welded solid and the bolt together clamps don't hold well because they flex inside the coupling. ussally a 1" weld on the bottom of the pipe where its clamped is enough to take out any downward flex and then it gives still when needed
Yetti
Old January 14th, 2006, 07:57 PM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
:tonka:
JcrOffroad
Zoom Zoom!
Page generated in 0.23015 seconds with 53 queries
