Anyone know what axles are in a 2000 F250 Super Duty? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2005, 10:52 PM   #1
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Default Anyone know what axles are in a 2000 F250 Super Duty?
It has front leaf springs, solid axle. It has the v10 and auto in it also.
Old December 16th, 2005, 09:49 AM   #2
Bones
Bones's Avatar
Front is a D50. A "hybrid" if you will.
Most people will tell you it is a D44 center section. It isn't. It is bigger than a D44, but not as big of as a D60. I am pretty sure it is a 30 spline shaft and it uses D60 outers. Should be plenty of lockers for it.
But fair warning, its an expensive axle to repair, as far as hubs/bearing.
I remember reading something on Pirate where someone shaved the inside of the pig and ran a D60 r/p and shafts...
Rear could be a few things. Either D60, D70 or Ford sterling 10.25
Look at the center section, and then go here
http://www.coloradok5.com/axleguide.shtml
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Page generated in 0.16521 seconds with 29 queries
