~65k 4.0/NV3550/NP231 w/ Short SYE from 04 TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 25th, 2012, 10:47 PM   #1
Bill3753
Default ~65k 4.0/NV3550/NP231 w/ Short SYE from 04 TJ
Swapping in a 5.3/auto set up.
Engine is a stock 4.0 with about 65k on the clock in good running condition. Since its from an 04, its a coil pack engine, ect. I think it would a a bolt in replacement for a 2000-2005 TJ, but don't quote me on that. Will come with all the accessories, ect.
Transmission is a NV3550, stock. 65k on the clock as well.
Transfer case is a NP231 with a short SYE installed (0 Miles since SYE install). You guessed it, 65k on it too.
I completely disassembled the case when I did the SYE and everything looked great inside.
This comes with everything you need to swap from an auto to a manual as well. Since I'm going auto, I don't need any of it. Pedal, slave cylinder, clutch, flywheel, starter, ect. Its all coming out together.
Everything is still currently installed and will remain so until sold. Also, I'm not interested in parting it out at this time. Located in Groton, CT and can deliver within reason. Would make a great swap to an older carb'd CJ/YJ or stock replacement for an old worn out TJ.
Asking $1800.00 for everything. Nothing at all wrong with anything here. Just upgrading. Would trade for an Atlas; maybe a Stak. Would need 32 spline input and DD. TH400 adapter would be a plus.
If this sells, I could also add in a 100% new (just used for mock up) PSC High Capacity power steering pump. Willing to work a deal for it all, but as listed it comes with the stock pump.
Bill3753 is offline   Reply With Quote
Old March 26th, 2012, 12:02 PM   #2
1 ton tj on 40's
1 ton tj on 40's's Avatar
dam wish you where closer i need a 4.0 motor.
Old March 28th, 2012, 05:37 PM   #3
Bill3753
Ttt
Old March 30th, 2012, 05:54 PM   #4
Bill3753
Ttt
Old April 4th, 2012, 09:26 PM   #5
Bill3753
Ttt
Old October 10th, 2012, 05:07 PM   #6
j3willys
dats what i'm talkin bout
j3willys's Avatar
Send a message via AIM to j3willys
I know this is from a few months ago, but do you still have this? I'm planning on swapping out the auto.
j3willys is offline   Reply With Quote
Page generated in 0.21350 seconds with 41 queries
