Fuse Locations for 98 XJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2005, 10:18 PM   #1
Default Fuse Locations for 98 XJ
Anyone have a drawing for what fuse is which, for a 1998 XJ?
Maybe could snap a digital photo. I believe the location chart is located in the owners manual.
Unfortunately, my XH has no manual with it, and its got several things not working (horn, dome like, fog lights, hazards..).. the PO installed an amp and the wire ducks under the weatherstripping which let some water leak during heavy rains. The leak was right next to the fuse block, I'm curious if it blew a couple due to the water, as those particular fuses don't blow that often..
But.. I need to know where they are, to start figuring out wahts going on..
If anyone has the diagram and can snap a nice digital photo, I'd much appreciate it. Can email to haggar1850@comcast.net, if you aren't able to upload it somewhere.
Or even just list them in order?
Thanks
Old December 15th, 2005, 10:38 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Jason IIRC that fuse will be in fuse box under the hood. It should be the one in a yellow holster that is a quick pull/push for dealer prep. Atleast for the dome light.
Old December 16th, 2005, 05:30 AM   #3
chuckhubbert
chuckhubbert's Avatar
Default If this hasn't been done by tonight...
I'll get my owners manual and/or Hayne's and see if we can't write it up or take pics or something after I get home from work. (And before I put my tow hooks on...)
Chuck
chuckhubbert is offline   Reply With Quote
Old December 16th, 2005, 07:05 AM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the cover for the fuse block has the layout printed in the plastic on the inside, if you have that the rest should be easy. also if you have a test light you can probe the fuses without removing them and see if they have power on both sides.
Yetti
Old December 16th, 2005, 08:21 AM   #5
No, the fuse box panel has a note that says: See Owners Manual for Fuse Locations"
There are at least 4 different circuits out. Yeah, I can just yank every fuse and replace any bad ones. But I'd like to have the locations for future troubleshooting.
Heh, I think I have a test light somewhere.... next to the true RMS Fluke and the Tektronix digital Oscope I use for most diagnostics, its decidedly quaint..
Old December 17th, 2005, 07:55 AM   #6
chuckhubbert
Default Fuses
Sorry I didn't get this done last night...
The fuse panel in the passenger kick panel has 27 fuses or at least sockets. The left side are numbered 1 - 14 and the right are 15 - 27. Fuses 1, 2 and 15 are "regular" size, the rest are minis.
From the owners manual, page 194.
Left column:
1 - 25A - Power Outlet
2 - 25A - Cigarette Lighter
3 - 10A - Left headlight high beam
4 - 10A - Left headlight low beam
5 - 10A - Right headlight low beam
6 - 5A - Instrument panel dimmer
7 - 10A - Left parking light
8 - Open
9 - 10A - Headlight delay, overhead console cluster
10 - Open
11 - 20A - Run/Start Ignition, Daytime running lights
12 - 10A - Rear window defroster, turn signal/hazard flasher
13 - Open
14 - 10A - Heated Mirrors
Right Column:
15 - 25A - Power door locks
16 - 10A - Right headlight high beam
17 - 15A - Radio
18 - Open
19 - 10A - Starter relay
20 - 10A - Trailer towing package
21 - 15A - Horn relay
22 - 20A - Rear wiper
23 - 10A - Right parking light
24 - Open
25 - 15A - ABS, Climate controls, Cooling fan, brake switch
26 - 10A - Airbag control module
27 - 10A - Airbag control module
Old December 17th, 2005, 08:21 AM   #7
Awesome, man! Thanks!!
Old December 17th, 2005, 11:39 AM   #8
PavementPounder
PavementPounder's Avatar
What's an "XH"?
:tonka:
Old February 20th, 2008, 11:43 AM   #9
brimy311
Smells like a Fork Liftis
brimy311's Avatar
Thanks
You posted your Private email address! ZOMG!
JcrOffroad.com
Like us on Faceook!
Page generated in 0.28296 seconds with 50 queries
