The Great Dodge Switcheroo Work Truck Project - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 28th, 2012, 09:34 AM   #41
kkodet
kkodet's Avatar
Drivers side ended up being just as bad in the bottom of the wheelwell as the pass side, so I'll have to do same repairs.
Old March 28th, 2012, 12:51 PM   #42
kkodet
kkodet's Avatar
Both sides repaired. Brought up bent in floor center with jack. Inner fenders are now very solid and fairly straight.
Old March 28th, 2012, 01:20 PM   #43
kkodet
kkodet's Avatar
Rear edge of bed also shot. More plate has been ordered.
Old March 28th, 2012, 02:03 PM   #44
kkodet
kkodet's Avatar
The spot welds on the inner fenders and bed floor were fairly easy to drill. The rear crossmember however is another matter. It appears to be hardened. After dulling a few bits I brought out the fire drill and it made quick work of the job.
Old March 28th, 2012, 04:19 PM   #45
269bigoldodge
269bigoldodge's Avatar
Nice work
269bigoldodge is offline   Reply With Quote
Old March 28th, 2012, 04:50 PM   #46
lgottler
lgottler's Avatar
When you get done, call me and I'll come over to help and drink a beer.
lgottler is offline   Reply With Quote
Old March 28th, 2012, 04:51 PM   #47
kkodet
kkodet's Avatar
Originally Posted by 269bigoldodge View Post
Nice work
Thanks!
Rear crossmember cleaned up nice. Since crossmember will be impossible to paint I hit it with some of thst rust preventer stuff.
Old March 28th, 2012, 06:10 PM   #48
kkodet
kkodet's Avatar
Patches are done!
Old March 28th, 2012, 07:14 PM   #49
lgottler
lgottler's Avatar
Maybe before you paint it all up you should add some plates in the corners with some tie down loops or something?
Old March 28th, 2012, 08:53 PM   #50
kkodet
kkodet's Avatar
Those are coming tomorrow.
Old March 29th, 2012, 08:26 AM   #51
kkodet
kkodet's Avatar
Last thing last night I did was use seam sealer on all the joints and such. I let it dry overnight so I can get stuff primed and such today. I did the joints from under the bed as well.
Old March 29th, 2012, 10:16 AM   #52
kkodet
kkodet's Avatar
Since bed is off I took opportunity to clean up the bottom of the back of the cab.
Old March 29th, 2012, 10:20 AM   #53
kkodet
kkodet's Avatar
Primed and hole cut for hitch. This is as far as I'm going with inside of bed for a few weeks. When I have time, I am going to clean up surface rust and use some sort of liner.
As a test, I tried some spray can bedliner stuff for underneath. It's O.K., but I don't think I'd use it in a bed.
Old March 29th, 2012, 10:47 AM   #54
kkodet
kkodet's Avatar
It could be the paint fumes talking, but rustoleum gloss white seems to be a pretty good match for 1997 Dodge white.
Old March 29th, 2012, 11:29 AM   #55
I suck cocks. Lots of them.
locally famous
why such thick patch material? is that 3/16"?
Old March 29th, 2012, 11:34 AM   #56
kkodet
kkodet's Avatar
No, it's 1/8. Thats the thinnest they had in stock.
I also carry alot of engines and other heavy stuff and am constantly smashing down my bed floor. So hopefully this will help a bit.
Old March 31st, 2012, 04:04 PM   #57
kkodet
kkodet's Avatar
Sorry for the lack of updates the last few days, I've been busting my rear on this.
With the help of some good freinds we got the bed on and doors hung. Everything went fairly smooth, except we had to move the gooseneck forward to the next set of holes, which meant taking bed off.
I still have some stuff to do after the florida run, but shes good to go for now. I put over 200 miles on her yesterday with no issue. Tomorrow I leave for Florida. Here she is all fat and sassy.
Old March 31st, 2012, 08:20 PM   #58
kkodet
kkodet's Avatar
A couple of other notes from the last couple days:
1995 and 1997 Taillight wiring harnesses are different and needed to be swapped.
The doors from the 95 were 1999 factory replacements, presumably under warranty. When I switched over my door handles (to retain my locks) the lock to latch rod had a different attachment and I had to use the rods from my doors to make work.
The 1995 bed used the old style small pin tailgate hinges. I used a newer tailgate and the hinges needed to be swapped.
The plastic license plate holder is MUCH easier to install with the rear bumper off, but can be done with a stubby philips.
Old March 31st, 2012, 08:27 PM   #59
kkodet
kkodet's Avatar
Today I added some tie downs in the bed and added two extra power outlets under the console in the back seat area for the kid's gizmos. I also added a fire extinguisher which is required for commercial vehicles.
The TO DO list for my truck includes:
Replace front fenders
Repaint rockers and roof
Replace hood
Get dually fender lights working
Install new wheels and tires. I just aquired a set of 19.5 8 lug wheels from a bread truck and had them bored out for dodge hubs.
Remove rest of black trim
Get A/C and cruise working
Get truck re-lettered
Old April 1st, 2012, 09:52 AM   #60
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
awesome work!
Page generated in 0.28667 seconds with 84 queries
