The Great Dodge Switcheroo Work Truck Project - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2012, 01:31 PM   #21
kkodet
kkodet's Avatar
Rear in with help of new U-bolts and shackle from Marysville truck (good people - fast and quality parts)
Leaves didn't seat right first time in perches. Figured out perches were filled with a stone like corrosion. Evedentially the leaf pins go further into perches on 2wd than 4. Took a bit with a chisel to clean them out.
Side note - locked dually axles are a pain to manuever into place by yourself! But I guess that means I now have a 4x6 instead of a 1x4 :D
Old March 25th, 2012, 10:01 AM   #22
kkodet
kkodet's Avatar
While the bed is off I installed the new B&W hide a goose hitch setup. Directions (with bed on) say its a 2-3 hour job. With bed off it took me 30 minutes or less.
I did the hitch install before finishing up plumbing and such in case of any clearance issues. There were none.
Old March 25th, 2012, 11:18 AM   #23
kkodet
kkodet's Avatar
The dually truck did not have a sway bar, my truck did. I planned to use it but discovered the mounts are completely different. The dually mounts are tucked in closer to the axle and do not span the tube. It would be simple enough to weld on different mounts, but since I'm on a bit of a time constraint I just removed the sway bar for now. Maybe I'll swap it on in the future.
You can see in this pic the new Gabriel Maxcontrol shocks.
Old March 25th, 2012, 02:19 PM   #24
kkodet
kkodet's Avatar
Heres a perfectly assinine discovery. Extended cab vs. Reg cab parking brake cables are different AT THE AXLE. Obviously the mid frame cable needs to be longer due to the extended cab, but whats the point of making them all different? The axle end cables are about 4 inches TOO LONG from the reg cab.
I would just replace both cables, but the pass side one is special order and wouldn't be in for 4-5 days. Fortunately they can get me the drivers side one by tomorrow (the one from my srw axle was busted)
I think I can reuse my Pass side one. It's crusty but still works.
Old March 25th, 2012, 02:46 PM   #25
kkodet
kkodet's Avatar
Oriellys can supposedly get my pass side one by morning woohoo!
Old March 26th, 2012, 05:51 PM   #26
kkodet
kkodet's Avatar
Cables came in. Found out passenger side brake shoes were installed backwards and toast. So between business paperwork and calls today I've been piecing together rear brakes. Lines and driver side wheel cylinder were very crusty and suspect, so they got replaced as well. I was able to repair/reuse e-brake cable brackets.
Old March 26th, 2012, 07:48 PM   #27
kkodet
kkodet's Avatar
Axle all buckled up........finally! My truck has working parking brakes again. Probably first time in 350,000 miles!
Now I just have to bleed the brakes and the rest is cosmetics.
Old March 26th, 2012, 07:50 PM   #28
capone
capone's Avatar
Great work Keith!
capone is online now   Reply With Quote
Old March 27th, 2012, 07:57 AM   #29
kkodet
kkodet's Avatar
Arg, morning be here.
Todays challenge. Bleed brakes then get to work on this.
Old March 27th, 2012, 08:13 AM   #30
kkodet
kkodet's Avatar
Brakes are bled.
Funny story:
Last time I bled the brakes in this truck I was having trouble getting one wheel working, so I got the wife at the controls and asked her to slowly depress brake pedal. She kept doing it and doing it, but I was getting no pressure at the cylinder. After about 20 minutes of this, I figured out she'd been pumping the clutch pedal :p
Old March 27th, 2012, 08:35 AM   #31
mschaffer66
mschaffer66's Avatar
Originally Posted by Route55 View Post
Brakes are bled.
Funny story:
Last time I bled the brakes in this truck I was having trouble getting one wheel working, so I got the wife at the contols and asked her to slowly depress brake pedal. She kept doing it and doing it, but I was getting no pressure at the cylinder. After about 20 minutes of this, I figured out she'd been pumping the clutch pedal :p
That's why the oven doesn't have a clutch...
Old March 27th, 2012, 08:37 AM   #32
kkodet
kkodet's Avatar
Marking sections to be cut out. Small holes drilled from underneath help locate locations of underbed crossmembers, as I don't want to cut into them.
Old March 27th, 2012, 08:55 AM   #33
kkodet
kkodet's Avatar
Nice.
On that note, I've figured out there are only 3 types of people in this world.
1. Those who can cook.
2. Those who can't cook.
3. Those who think they can cook.
Unfortunately I'm number two and married number three. We eat out a lot :)
Old March 27th, 2012, 01:05 PM   #34
kkodet
kkodet's Avatar
Some of the cancer cut out. I'll have to patch the bottom of the wheel house.
Old March 27th, 2012, 01:17 PM   #35
Paintballpsyco236
Paintballpsyco236's Avatar
Send a message via AIM to Paintballpsyco236 Send a message via MSN to Paintballpsyco236 Send a message via Yahoo to Paintballpsyco236
Brakes are bled.
Funny story:
LMAO AWESOME lol... Looking good so far, can't wait to see it in person.
Paint
Paintballpsyco236 is offline   Reply With Quote
Old March 27th, 2012, 01:44 PM   #36
kkodet
kkodet's Avatar
Bottom of wheelhouse cut out and flanged. While I had room, I took the time to hammer and dolly the big dents in the fender. I didn't get too crazy, as I don't have a bunch of time, plus I'm planning on using some sort of spray or roll in bedliner soon.
Old March 27th, 2012, 02:03 PM   #37
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
@clarkstoncracker
Old March 27th, 2012, 02:47 PM   #38
kkodet
kkodet's Avatar
Wheelhouse patch tacked in. The rest is prepped.
Old March 27th, 2012, 02:54 PM   #39
kkodet
kkodet's Avatar
Floor patch. 1 inch 90 degree bend that will help with welding and strength.
Old March 28th, 2012, 08:59 AM   #40
kkodet
kkodet's Avatar
Patchs all welded in on pass side. I debated whether to fill and or smash up the low ridge areas and decided to leave them as is, and fill with seam sealer before coating over.
Page generated in 0.36491 seconds with 84 queries
